Question about Canon Ir 3300 B/w Copier image Runner Series
Screen is flickering ( i.e. ON / Off) and afterwards ir 3300 shows E0000. whats the problem
Replaced Fixing unit and hdd/ power supply and boot ram /control panel and checked total harness of machine.
  • 52 Answers
Check heater unit...
Posted on Jan 04, 2015
Power light comes on but touch screen display is blank
Does the machine initialise? You should be able to hear it??? If not then it could be the formatter board but if it does initialise then check the screen or the cable
Jul 13, 2016 | Canon IR 3300 Digital Copier
Canon ir 3045 showing E0000-00014 please help.
Check the fixing unit harness and Thermistors.
And check the Connectors of Fixing unit.
If Problem Persists Replace DC controller.
Jun 01, 2016 | Canon Office Equipment & Supplies
Need help with my washer with a code on the panel
The "F06" fault code indicates a drive motor tachometer error. This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes.
Possible Causes/Procedure:
Unplug washer or disconnect the power supply.
Check the wire harness connections between the motor and motor control unit and the harness connections between the motor control unit (MCU) and the Central Control Unit (CCU).
Based on your symptom and details, the intermittent (F06) error code is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). if the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU).
Jun 12, 2015 | Frigidaire Washing Machines
My canon ir 3300 have fixing assy error e00001-0002
The fixing film unit faulty.Thermistor might have a short circuit.May also be the main power supply or DC controller PCB
Oct 22, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How to solve error code of E000002-0000
The problem is in temperature of a fixing film.Try to clean the heater,put on the grease...If ther's still a problem,replace the heater
Sep 23, 2014 | Canon Ir 3300 Black & White Copier
I have a cannon ir 3300 machiene and occured a problem with a error code e000000-0000 please help me out to remove this problem my technician has asked me to change the filament which is worth 12000.w
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Feb 17, 2014 | Cannon Office Equipment & Supplies
Astone CE-260 netbook 1GB RAM, 60g HDD / Power but Total Darkness ??
Sounds like an expensive door stop! It will not be the Cmos battery as if it were flat the system would still run but it would have to look up the system content at every boot. Try removing battery, power supply and RAM. Power it up with the power supply.If it now works, add RAM then HDD. If it doesn't. a car ramp or door stop is possibly best.
Dec 21, 2013 | Computers & Internet
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Cannon-3300 Copier Error code E000-0000 rectify the problem
E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
the fixing film unit.
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Jan 18, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Ir 3300 B/w Copier image Runner Series Logo
66 people viewed this question
old marine
old marine
