Question about Akai Televison & Video
Replacement lens for akai
I missplace rhe lens
  • Lawrence Oravetz Dec 13, 2014
    Hi monares , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Akai what? Camera, projector. Lenses can be had on their website .
Wel i have rhe gear box and belhousing lose bot i can not see how rhe box is going to come out to replace rhe cluth
NOW if knew what make year and model i may be able to help ,must be a english or aussie asking this question as americans do not how to drive a PROPER CAR
Mar 10, 2012 | Cars & Trucks
Picture seems very faded on tv it is approx 9 years old do they have main bulbs that can be replaced when picture starts to look washed out
If model number is correct the akai is a samsung; from the rear with the cover removed are three rather large black lens (one for each picture tube) that point upwards.
If the set has not been serviced for a long time clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on it.
These are the light source for your picture and if dusty the picture will be darker and dull looking.
SD TECH
Sep 19, 2011 | Akai PTH5498 54" Rear Projection...
My Akai dvd player shows "no disc" after loading a dvd. The tray sometimes makes a grinding noise when opening and closing as well.
The reason the player is not reading the disc and showing no disc is either because the disc is not sitting properly on the lens from the disc tray, or the lens is weak or the lens is dirty.
To test if it is the disc tray, open the cover of the player with the appropriate screwdriver, place a disc directly on the tray and apply a little pressure on the tray, if it reads the disc, then it is the tray.
All you have to do is to adjust the disc tray and screw it tightly.
To test if the lens is weak, try several DVD disc on it,and test them also on another tested ok player, if it does not work on your player and works on other players, then the lens is weak.
to fix this, get the appropriate screwdriver, open the cover and unscrew the disc tray.
You will gain access to the lens, carefully disconnect the lens and replace it with a new lens. then it will be ok.
To test if it is just that the lens is dirty, clean the lens with a lens cleaner and test a DVD to see if it will work.
Take care.
Jun 14, 2010 | Akai DVPS760 DVD Player
My AKAI tv/dvd combo - DVD quit working.
Most times it's video read issue such as a dirty lens on the laser.If you smoke in the house or use a fireplace there is a lot of airborn stuff to leave a slight haze on the lens making reading the disk impossible.Try a standard cd or dvd lens cleaner.The on that looks like a cd and uses alcohol on one of the cleaning brushes on the disk you've got a 50 50 chance.
good luck
Rich
Jun 06, 2010 | Akai LCT2721AD 27 in. LCD Television
Akai DVDP5851 dvd player. 'Loading' but disc doesn't play
the lens of dvd player is weak so replace the lens it will start working or use the lens cleaner it will hep you to check the lens either it is ok or not
Apr 29, 2010 | Akai DVDP5851 DVD Player
My camera is out of focus tell me whats the problem
failure of focusing unit of rhe lens/replace with anew unit
Mar 01, 2010 | Fuji FinePix F420 Digital Camera
I have the akai model # ptf492s and the white colors are yellow
I'm almost positive the problem is you have fungus in the CRTs. I know this sounds strange, but it's true. Basically there is coolant fluid in the lamps that develops fungus over time and turns yellow. It should be clear. If you take the back off the television, you will see the 3 lenses (red, green, blue) Each of the lens is held on with 3 screws. Remove the adjustable lens and look at each CRT. Shine a flashlight in they should look white. From what I've read, blue develops the problem first, then green. You can replace the fluid. Look up TV coolant replacement online. It's not to difficult, but you cannot get any of the fluid on the circuit boards or it will ruin it. Mine had a lot of fungus in the blue CRT and a little in the green. The picture looks 100% better now. Good Luck.
May 12, 2009 | Akai PT5492S 54" Rear Projection...
Change CRT coolant in AKAI Pt5598HD
The CRTs in modern TVs do not hold a charge because the HV circuit shunts it to ground whenever you power down the TV. You can clean the lens of the CRTs but you can't change the coolant or should you even try. You'll notice that its sealed from the factory. If you suspect a problem with the coolant or that it has dried up or leaked out, you must replace that CRT.
michtech
Feb 20, 2009 | Akai PT5598HD 55" Rear Projection...
Cleaning
ok with a soft clean piece of cotton with no water or liquids
Sep 01, 2007 | Cameras
Televison & Video Logo
29 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
