Got a daikin ftksgvma 7kw. Got no led lights on the head unit or noise when I press on from the controller also won't turn on from manually. Force start from compressor will only turn on compressor but have power on compressor and indoor unit. Have done the fault led"s on the compressor and it shows it may be indoor board. Jus wondering if theres a possible way of fixing it beside buying a new one
  • Heating & Co... Master
  • 1,291 Answers
You can cycle the power from the disconnect outside. Leave off for 10 seconds or so. Sounds like you're on the right track with the board.
Posted on Aug 07, 2017
koolbreezes
  • 540 Answers
SOURCE: split AC 1200-BTU Kenwood Model ANK12P Pearl series Power lights ON but Unit does not become ON.
HE, I Dont Know where youre getting these #'s from but the only thigs comes up under kenwood model ank 12p pearl series is "GERMAN" websites and nothing I could understand websites.
Posted on Sep 06, 2008
  • 5 Answers
SOURCE: Hitachi ras-5h gse
first: The compressor is deffective
second: Fan capacitor is deffective
3rd: Running capacitor is deffective
Posted on Jan 26, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
  • 10 Answers
SOURCE: Is about the 5hp haier
Test the capasitor in the compressor unit there it could be bad or the compressor froze up.
there is a clicks on over load device inside the plastic box on the side of the compressor some
times they go bad too.
Posted on Oct 09, 2010
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
DAIKIN Aircon Multi Unit - One head unit not working, others are fine. No lights or response
Check for power at unit . If there is power to unit check for blown fuse on circuit board or bad board .
Nov 11, 2014 | Heating & Cooling
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
My airwell aircon won't respond to my remote, my
FROM THE AIRWELL RC-4 REMOTE CONTROL MANUAL
NOTE THE COMMENT ABOUT THE RESET AND THE SIMULTANEOUS SELECTION OF THE + - SET and CLEAR BUTTONS to effect a reset after replacingg batteries
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&ved=0ahUKEwi_8IKByO3UAhVDVbwKHQB1B5AQFghUMAU&url=http%3A%2F%2Ftrade.jng.com.au%2Fhome%2Ffile%2F9031&usg=AFQjCNGiMLYsIf_M8G3-H0Ccni6xhE_0Ig&cad=rja
Jan 12, 2013 | Heating & Cooling
Nuvelli NUV2882 Stereo Bluetooth Headphone User Manual
There's no manual available, but if you want to pair your headphones with a computer or a phone follow this steps:
1.- Fully charge headphones (leds turn from red to steady blue
2.- Press for 8 seconds the lower button on the right (it has a phone symbol)
pressing the "phone" button will turn on the headphones, but if you keep pressing it will force the device to go to " Pair mode" you call tell is ready by noticing the LEDs turning blue and red. onces pairing is successful you will see a steady blue LED.
Apr 04, 2012 | Radio Communications
Daikin FTY45EV1A split system wont turn on, has flashing timer light on. I turn the unit on and off by the remote, still doesn't work. What does the flashing timer light mean?
The only thing I can find on "Daikin FTY45EV1A" is on Russian, and I don't read that language. If you have a manual for that system then find the section on error codes and see if that flashing light gives you a pattern. Usually they flash in two sections giving you a two digit code. I.E. 1 flash pause then 3 more flashes would be a 13 code. Read your manual and see if it gives any help.
Jun 14, 2011 | Heating & Cooling
My daikin inverter does not turn on. when i press on on the remote, the flaps open all the way down then close. the green operation light is flashing.
Seek a refrigeration mechanic. With out looking at the unit it is to pin point problem.
More than likely a PC board issue on the indoor or outdoor unit. Does your remote control give you an error code. If possible look at the users manual on how to get the remote to give you the error code.
Nov 26, 2010 | Cfm Daikin R410a Split System Air...
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Quantum 3213. the door opener opens neighbors and visa versa
You can follow these instructions to change the code of yours. Might work for you.
NOTE: You must change the transmitter's code before programming the transmitter to the motor head unit.
The following steps describe the process to change a Quantum™ and Classicdrive™ security code.
This process only works fro transmitters with a GREEN LED and a "U" in their model number, such as "02-3047 2B U" or "02-3047 2B UH".
Changing the Transmitter Code
1. Press and hold the button on the transmitter that you want to change. The GREEN LED will flash once and then turn off.
2. Continue to hold the button until the GREEN LED begins to flash (approx. 10 seconds).
3. When the GREEN LED flashes, immediately release the button and then immediately press and hold the same button again. The GREEN LED will now come on steady.
4. Continue to hold the button until the GREEN LED begins to flash (approx. 5 seconds).
5. When the GREEN LED flashes, immediately release the button.
6. The code for this button has now been changed to a new randomly generated code. Do not push the button again until instructed in "Programming Transmitter to Power Head Unit".
7. You must now re-program this transmitter to the motor head unit. See "Programming Transmitter to Power Head Unit".
1. Press the PROGRAM button located on the garage door motor head unit once. The PROGRAM STATUS light on the motor head unit will turn on and remain lit for one minute, indicating that it is ready to learn the Transmitter code.
2. Press the same button on transmitter as you did in "Changing Transmitter's Code" above. The PROGRAM STATUS light will turn off indicating a successful learn.
3. Press the same button on the Transmitter once more to operate the door.
4. If you are unsuccessful in programming the transmitter to the motor head unit of if the button does not operate the door or if you wish to program another button to operate a different door, you must change the transmitter's code.
Battery
If the LED does not turn on when button is pressed, replace battery.
Jan 18, 2010 | Universal Garage Wireless Keyless Entry...
Hi, i have 2 daikin air conditioning unit, 1 is working perfectly but when the 2nd is turned on the power light just flashes and nothing happens, any ideas thanks.
The flashes are codes for different problems the unit may have, count the flashes and check your owners manual this will tell you the problem and the solution, or turn the breaker off for 5 minutes and re-start the unit this will reset it the unit should work if the problem start again you will need a service man. hope I was able to help you.
Nov 27, 2009 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
