Hi I have a old ftks71gvma r22 inverter 7kw daikin and the ac won't turn on by controller. When I pres on the ac won't even beep or light up whatsoever, tested and has power to outdoor unit and indoor unit. Only way to turn on is force start at the outdoor unit (condensor runs) indoor unit lights still won't come on and fan won't turn on. If anyone could help please
  • 44 Answers
SOURCE: Unit wont start, flashing lights on indoor unit, fuse may be gone
How old is it? Can you justify spending lots of money on an older system? Sounds like a transformer issue. Sometimes if the low voltage wiring gets shorted outside via dog or weed eater it will short the transformer. But if transformer is on control. Controls are cheap at supply houses maybe not from technicians
Posted on May 29, 2009
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
drsn
  • 42 Answers
SOURCE: My Outdoor unit not starting ... but indoor is running fine
check the capacitor. it might be defective, i would have a certified electrician or hvac tech trouble shoot it..if you never had worked on a/c b4...........you could probably ruin it more....................if you dont know what your doing......
Posted on Apr 16, 2010
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
  • 413 Answers
SOURCE: AC Starts normally but after some time of coolinf
Probably overheating. Check the outdoor coil and see if it is stopped up with dust, grass etc. If so, disconnect power to the unit, and clean the condenser coil with water or air. Be careful not to bend the fins if you use a water sprayer.
Posted on Apr 11, 2011
Daiking inverter ac work slow after one year
Low refrigerant issue need to refill refrigerant
Jul 14, 2016 | Inverter Heating & Cooling
Streamline. What does error E0 mean?
How to fault find a Daikin Air Conditioner, troubleshoot split ...
? 4:22
www.youtube.com/watch?v=i30rEvyuDKs
Feb 10, 2012 - Uploaded by Fully Airconditioned This video shows how to get fault code from remote control and reset fault, you ... Daikin Inverter AC Unit Fail - Moisture / Salts Damage to PCB ...
Sep 30, 2015 | Inverter Heating & Cooling
Is it better to by air conditioners with R - 410 GAS OR R - 22 GAS
R410 units are cheaper now but not as effecient as R22, also R22 is much more expensive and most likely you would have to use R22 a to recharge unit if it as allowed where you live .
Oct 02, 2014 | Cfm Daikin R410a Split System Air...
Just asking how many amps existing Sanyo SAP-K181AHA would be connected to in Australia. Need to replace it, is 4.5Kw cooling and same price to replace with 7Kw but unsure if 30amp already in place
The 4Kw constant speed Ac will draw about 7.6 amps @240vac while the 7Kw Ac unit will draw around 13.8 amps @ 240vac. This is normal running. extreme conditions will be slightly more no doubt. The figures are approximate.egardsCol R.digital controls.com.au
Mar 05, 2011 | Heating & Cooling
My daikin inverter does not turn on. when i press on on the remote, the flaps open all the way down then close. the green operation light is flashing.
Seek a refrigeration mechanic. With out looking at the unit it is to pin point problem.
More than likely a PC board issue on the indoor or outdoor unit. Does your remote control give you an error code. If possible look at the users manual on how to get the remote to give you the error code.
Nov 26, 2010 | Cfm Daikin R410a Split System Air...
My lcd display turns off randomly
check power saving settings under control panel
Dec 01, 2007 | Acer Aspire 9300 Notebook
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
