Question about Tracrac 2003 GMC Sonoma - 6 short bed - T-Rac Truck Bed Rack
Can fault code p0135 cause a gm 4.3 to miss or missfire
Distributor cap & rotor along with replacing the spark plugs
PCM code P0306 and P0175 together what can cause both these code at the same time?
is it a6 cylinder? Its ignition fault check spark plugs, spark plug wires, distributor cap, and rotor, if it has one & check the coils or coil packs).
just type the error codes into google and you get hundreds of hits and ideas of what to check
Nov 03, 2014 | Cars & Trucks
99 tahoe read code p0300 what does that mean
Po300 is a multiple random misfire there several things that cause this GM had an issue with the coil wire arcing to the transmission dipstick tube the new routing is to go over the plugs and remain on the inside of tube (old way was behind) USE a new wire. #2 dirty fuel (water contamination) As for the p1345 code this could be caused by ignition arcing inside Distributor Cap I would suggest replacing cap and rotor Clear codes This code will set once engine has gone over 1000 rpm's it updates every time to get spark advance correct if sets again distributor has moved this can be reset with a gm specific software scanner under camshaft offset specs 0 degrees to +4 max.
Apr 04, 2014 | 1999 Chevrolet Tahoe
P0305 and p0200 on a 2003 chevy blazer 4.3 , runs really rough
P0305 is a misfire on number 5 cylinder replace spark plugs, wires cap and rotor button. Please note: Does the ac cooling line/hose go over top the distributor ? If so GM/CHEY had a problem when dripping from that AC line/hose dripped down onto the distributor. That caused miss fires after a time. I hope this helps, Lee.
Feb 09, 2014 | 2003 Chevrolet Blazer
I have a 98 honda accord 5 spd it has a 4cyl motor vtech i just need to know how to fix a miss fire in cylinder 2 and wich one is cylinder 2
Cylinder #2 is the the second spark plug counting from the right to left.
EX.Below are spark plug on engine
engine
' (oil cap) '
' (4) (3) (2) (1) '
'_________________'
Your misfire can be cause by couple of things but the cheapest way that you can try to fix your car is to do a tune up by replacing:
1)all spark plugs
2)do a oil change
3)spark plug wires
3)distributor cap and rotor
note misfire can be cause by:
1.bad gas
2.spark plug and/or wire
3.distributor cap and/or rotor
4.valve adjustment
5.injector
6.off timing
7.ECM
8.bad wiring(power, ground or feed line)
Jul 08, 2011 | 1998 Honda Accord
My jimmy seems to be missing, but only when it rains, I would like some help. Mary
depending on what motor is in your Jimmy and if it still has a distributor, that is where i would start. moisture will get in side the distributor and cause a miss fire. This is a common problem with GM trucks that still have distributors instead of coil packs. Try haveing some one replace the cap and rotor or silicone around the cap and see if it seals.
Mar 10, 2011 | 1999 GMC Jimmy
My 1996 chevy 1500 has a missfire i have
Well, First i would have replaced all of the spark plugs and the wires, Then moved to the cap or rotor second, but in that case, did you check the spark plugs and wires, when was the last time they were changed? Maybe they were changed already and that's why you when straight to the distro? Is there a computer code for a misfire, or it feels like a misfire when it's running?
May 09, 2010 | Chevrolet 1500 Cars & Trucks
Check engine light flashing runs rough not firing on all cylinder2000 lincoln navigator with large triton engine Hooked up diagnnostic and it said 1. system too lean bank #2 2. Unable to bleed up fuel tank...
you may try your rotor button and distributor cap. and spark plug wires. try your map sensor also they tend to cause a lot of misfiring if they go bad.hope this helps.
Apr 20, 2010 | Lincoln Navigator Cars & Trucks
Engine cough
Go to Auto Zone and have the Suburban scanned for DTC codes, Auto Zone scan for free and most Auto shop will do it for $10.00 to $20.00 since they want your business cause they know most large Auto Parts store scan for free.
It sounds like you have a miss fire which can be caused by and O2 sensor or dirty MAF sensor which can be cleaned or time to replace the rotor and cap, plug wire and spark plugs.
Note that the distributor cap and rotor is made of plastic and is know to crack do to time and heat. There is also a rubber valve or screen at the bottom of the distributor that get's dirty and the inside of the distributor collects with condesation and corrode the rotor and caps too.
Good luck and hope this helps, Get it scanned and see if it's a sensor that is causing the miss fire on the hightway. If not then replace the cap and rotor and clean out the distributor if needed. Inspect the plug wire and replace if needed and change the plugs.
Keep me posted. be glad to help you out.
May 28, 2009 | 1996 Chevrolet Suburban
Hi, I have a 1997 Porsche 993. Motronic 5.2 M07. I am getting these fault codes 1) 62 misfire emissions-relvant 2) 51 Cylinder 2 misfire emissions-relevant) 3) 54 Cylinder 5 misfire ...
misfire :-------- try checking your 02 sensors /fuel pump and filter.
for 51 cylinder misfire :---
Change the coil. Period. Very easy to remove from the vehicle if it's a 4 cyl. Follow that spark plug wire from the spark plug to the other end. What it's attached to you should replace
for 54 cylinder 5 misfire :---First you have to eliminate the most obvious problems, like spark plug and spark plug wire. If you replace those and you still have a misfire, then it's a good idea to look for a vacuum leak in the intake manifold
Mar 07, 2009 | Porsche 911 Cars & Trucks
1994 chevy s 10
The couple across the street from where I live, had the same problem. He also changed plugs and wires and even the coil. I told him to replace the rotor bug and distributor cap and all started running smoothly again. Looking at the bug and cap nothing looked bad other than a little wear. It even checked out using a meter. Only thing I could think of was that there may have been some hairline crake robbing the spark and causing it to missfire.... Don't really know.
Jun 11, 2008 | 1994 Chevrolet S-10
Tracrac 2003 GMC Sonoma - 6 short bed - T-Rac Truck Bed Rack Logo
74 people viewed this question
Top Tracrac Boating Experts
Lawrence Oravetz
Timllfixit
Are you a Tracrac Boating Expert? Answer questions, earn points and help others
