I have a wurlitzer juke box 1961 2500. I replaced the florescent bulb where the keys are. When I put it back together the keys will not engage. Do you think I blew a fuse. I should have unplugged it. I push them in they pop right back up. Any ideas?
    Champion:
    Habit-Forming:
  • 239 Answers
It's the same on any jukebox, if you don't have credit on the keys will not latch
Posted on Feb 03, 2015
5 Suggested Answers
SOURCE: Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Posted on Aug 25, 2008
  • 211 Answers
SOURCE: Wurlitzer 1015 CD 50 disk - florescent bulbs change
You have to rotate the tube 90 degrees until you hear a click, then it pulls straight out of the sockets at the top and bottom (towards you). In order to grip the tube Wurlitzer put a black plastic cap on the end of the tubes with a bit sticking out for you to get hold of. On models where the colour cylinder is flexable you can actually squeeze it in the middle and grab the tube that way.
Dave.
Posted on Nov 03, 2008
  • 195 Answers
SOURCE: How can I take out the side florescent bulbs encased in plastic?
Usually the plastic tube has two end caps that hold the plastic tube onto the lamp. These end caps allow the connection pins to go through a slot in the end of the cap.
If the lighting fitting is the turn type then turn the complete tube and over tube by the end caps and remove the tube/over tube. If it is in a lighting fitting where you just push the connection back and pull the pins out of the fitting.
The end caps will have a ridge that the plastic tube fitts into at each end.
I have seen some overtubes have screw on end caps.
Regards
Alan Hood
ami-man
UK
Posted on Aug 10, 2009
  • 567 Answers
SOURCE: wurlitzer juke box "Rave ON"
IF U REQUIRE THE SERVICE PROGRAMME EMAIL ME I HAVE IT ON DVD DISC philhemmings@hotmail.com
Posted on Sep 03, 2010
Where can I hire a repairman to fix my Whirlitzer juke box?
go google and type in--- service agents for wurlitzer juke box ---
find and agent closest to you and call him on the phone
Dec 23, 2016 | Audio Players & Recorders
How do I replace the light bulb in my 45 wurlitzer juke box in the round spinning tubes?
It depends how old it is. On the newer type there are two black tags on the ends of the light tube to help you turn it. It twists 90 degrees then pulls out backwards from the sockets along with the colour tube around it.
On the older type you need to remove a screw or two at the top plate, lean it backwards and lift up and out.
Dec 24, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a wurlitzer juke box 1965 and it's clicked off free play, it will only now play one record at a time by keeping pressing the reset button.
The free play switch is only supposed to allow one selection on most Wurlitzers. If you email me the model number, I may be able to advise how to put it on continuous free play. My email address is tech@wurlitzer-ohio.com.
Aug 07, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a Wurlitzer Juke Box (One More Time, 1015, Vinyl) & need to replace one of the florescent bulbs in the turning, side cylinder. Someone said to turn the color cylinder a quarter turn & it...
The actual light tube slides sideways into the socket and then is rotated 90 degrees so it clicks (quarter turn). It is physically impossible so wurlitzer added a black plastic cap at the top and bottom of the tube with a bit sticking out that you can use to turn the tube. So look at the very top and bottom of the actual light tube and try turning the black part.
Aug 05, 2010 | Wurlitzer Jukebox CD Player
I have a wurlitzer super star juke box. the
I think I can clear things up for you. The free play switch you're referring to is just to add credits. If you want continuous free play, I sell you a jumper plug to bypass the credit unit, commonally called BOAC, if you have a 3600 series Super Star. Please email tech@wurlitzer-ohio.com.
Mar 11, 2010 | Wurlitzer Jukebox 1015 One More Time...
Regards
Alan Hood
ami-man
UK
Aug 10, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer juke box "Rave ON"
Jun 22, 2009 | Wurlitzer Jukebox 1015 One More Time...
Dave.
Nov 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rowe juke box
Put in service mode, type 55, then hold reset down while toggling 9 to cut on or off.
Should say free play on display.
Aug 13, 2008 | Wurlitzer Jukebox CD Player
63 people viewed this question
 Grubhead
Grubhead
