Question about 2009 Ford Ranger - XLT - In-Channel Rain Guards
How do I locate and change the thermostat on 3ltr tdi 2009 ranger
Have removed the top radiator hose and housing mounted on the block but there is no thermostat or location for one. Need to find and locate to change over
  • 813 Answers
I dont no alot about this car but in my exspearence its normaly where you have been looking,but you could see if its nexst to the water pump,best of luck.(maybe the firmostate was missing to begin with)
Posted on Dec 15, 2014
How to change thermostat on a 2005 kia sedona
  1. Drain the coolant
  2. The thermostat is located at the end of the top radiator hose. Remove the drain plug from the radiator and flush the coolant into a pan.
  3. Remove the Upper radiator hose
  4. Loosen the clamps that connect the upper radiator hose to the housing and remove the hose.
  5. Remove the thermostat housing
  6. Loosen the thermostat housing mounting bolts. Remove the housing and pull the thermostat from it.
  7. Replace the thermostat
  8. Inspect the new thermostat and install it with a new gasket. Mount the housing and upper radiator hose. Then pour new coolant into the radiator.
Mar 18, 2017 | 2005 Kia Sedona
Where the thermostat is located on 2009 Dodge Nitro 4.0 lt
If you follow the top hose from the radiator to the top of the engine block there should be a housing at the end of it. The thermostat should be under theat housing. By housing I mean a hard plastic or metal part that bolts the hose to the block
Jun 14, 2015 | 2009 Dodge Nitro
Where is thermostat located on 2006 1.9 pd vw passat?
Follow your top radiator hose back to the engine and at the end of the hose is the thermostat housing usally 2 bolts mount it to the engine.Remove the 2 bolts and pry up on housing thermostat will be underneath.
Feb 03, 2012 | 2006 Volkswagen Passat
Dont no were the thermostat is for a ford ranger 2.50 turbo
Hi, remove the cap from the top of radiator and set aside. Locate thermostat housing on side of engine block. When you are standing in front of the truck, looking at the engine, the thermostat should be on the side of the motor block near the right front.
Apr 09, 2011 | 2004 Ford Ranger
I'm trying to locate the thermostat on my 2000 jeep grand cherokee
  1. On 2000 Jeep Grand Cherokee 4.7L V8
  2. Remove lower radiator hose clamp and lower radiator hose at thermostat housing.
  3. Remove thermostat housing mounting bolts, thermostat housing and thermostat.
2000 Jeep Grand Cherokee 4.0l v6
Note:on the In-line 6 4.0L model the thermostat housing is mounted at the top of the engine block next to the water pump.
Nov 14, 2010 | 2000 Jeep Grand Cherokee
What is the location of the thermostat on a 2006 sebring
follow the large radiator hose from the radiator to the engine, you'll see a large clamp holding the hose onto the neck thats bolted to the engine block, under the neck is where your thermostat is located
Jul 04, 2010 | 2006 Chrysler Sebring
Where is the thermostat on my 2002 dodge 1500 van and how do you change it?
hi this can be found by locating the top hose on the radiator, follow it back to the engine/motor, there you will find a housing inside the housing you should find the thermostat..you need to drain the cooling system Remove the radiator hose clamp and radiator hose at the thermostat housing, Remove the thermostat housing mounting bolts, remove thermostat housing ,then you can remove the thermostat it self thermostat...hope this helps happy 4th to you
Jul 03, 2010 | 1999 Dodge Ram
Location of 2001 2.7L v6 chrysler sebring thermostat location
Follow the TOP hose on your radiator to where it connects on your engine block. The thermostat is under the metal piece mounted to the block which the hose is connected to. It typically has to bolts to remove and you will find the thermostat under it once you remove the mounting.
Oct 03, 2009 | 2001 Chrysler Sebring
I was wondering where the thermostat was located
Follow the top radiator hose to the engine block. You will see a housing similar to the picture below. The thermostat is mounted under this housing.
Sep 20, 2009 | 1992 Buick Regal
How do you change the thermostat on a 98 ford ranger 2.5L
CAUTION If the radiator is filled to the top with coolant and the engine is run without the radiator cap in place, the coolant will expand and spill over as the engine warms up.
  • Drain some coolant into a clean container until the coolant level is below the thermostat housing.
  • Remove the upper radiator hose connection from the thermostat housing.
  • Loosen the housing bolts and remove the housing.
  • Remove the gasket and scrape it carefully from the surface of the housing and the mounting surface on the engine. If the gasket remains on either of the surfaces, there will probably bea coolant leak after reassembly. Some engines use a rubber O-ring to seal a thermostat housing.
  • Compare the size of the thermostat to the old one. They are of different sizes, types, and temperature ratings.
  • The temperature rating is stamped on the sensing bulb on the bottom of the thermostat. The temperature bulb faces the block.
  • When replacing a thermostat, be sure that the thermostat fits into the groove in the block or outlet housing. If the thermostat is installed upside down, the engine will overheat.
  • Install the gasket.
  • Reinstall the thermostat housing. Refill the system and run the engine or pressure test to check for leaks.
  • When the engine has reached operating temperature make sure the thermostat opens.
  • You should be able to see coolant circulating within the radiator.
  • Another way of checking thermostat operation is to feel the top of the radiator hose or use a thermometer or multimeter with a temperature probe to confirm that the coolant is warming up.
  • If the engine is overheating, but the top hose is still cool to the touch, the thermostat is stuck closed and must be replaced.
When replacing the thermostat, also replace the gasket that seals the thermostat in place and is positioned between the water outlet casting and the engine block.
Generally, these gaskets are made of a composition fiber material and are die-cut to match the thermostat opening and mounting bolt configuration of the water outlet. Thermostat gaskets generally come with or without an adhesive backing. The adhesive backing of gaskets holds the thermostat securely centered in the mounting flange, leaving your both hands free to align and bolt the thermostat securely in place.
  • Remove the thermostat housing.
  • Remove the gasket and scrape it carefully from the surface of the housing and the mounting surface on the engine. If any gasket remains on either of the surfaces, there will probably be a coolant leak after reassembly.
  • Some engines use a rubber O-ring to seal a thermostat housing.
Hopefully this is helpfully
Nov 17, 2008 | 1998 Ford Ranger SuperCab
2009 Ford Ranger - XLT - In-Channel Rain Guards Logo
63 people viewed this question
Top EGR Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an EGR Vehicle Part and Accessory Expert? Answer questions, earn points and help others
