Question about Crafts & Hobbies
How do I do concealed hings with the Milescraft Cabinetmate jig
Internet
Tip
Applying Concealer: Covering up Acne.Breakouts are embarrassing, but...
Applying Concealer: Covering up Acne.Breakouts are embarrassing, but fortunately, concealing problem areas can make imperfections disappear. Many products are even designed with medicating ingredients that treat and prevent breakouts. Read on to learn simple tricks for concealing acne. <br /><br />The first step in concealing acne is creating a flawless canvas on the face. Apply an oil-free moisturizer that doesn't clog pores to get rid of dryness and flaking. After allowing the face to dry for a few minutes, apply a skin-clearing concealer. Concealer reviews consistently rank Neutrogena SkinClearing Oil-Free Concealer as a great acne-fighting concealer. It covers up blemishes while treating the problem area with salicylic acid. <br /><br />After you've concealed the problem area, apply foundation to the face using a foundation brush. Using a brush can prevent future breakouts that are caused by oils from the fingers. Check out Neutrogena SkinClearing Oil-Free Makeup, which also contains salicylic acid, to treat and prevent future breakouts.
on Nov 22, 2010 | Health & Beauty
Toilet seat gural vitrifiye
I need a toilet seat.
The present one has the words GURAL VITRIFIYE on the lid.
It is a D shape and has concealed rubber fittings.
The hinge sockets are 19 cms apart.
The seat is 35 cms wide and 45 cm max length from front to back.
Thanks.
Can you advise please?
Jan 04, 2014 | Liebherr European Right Hinge Fully...
How to replace rear window taurus wagon
I have not done this myself and I don't know if there is a good walk through out there but I have to believe this is pretty straight forward. There should be a concealing cover that can be popped off that should expose what I am guessing to be a torx style nut to it. My only advice is to have a second pair of hands there to hold the glass in place while the hinge is removed.
Oct 09, 2012 | 2001 Ford Taurus
The inner pane of glass has smashed on our Zanussi ZBF 560 x single oven. I cannot find a way of either replacing the pane or the oven door as the hinges seem concealed Thanks
You will find some very helpful videos on how to do this by going to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter--- CLEANING OVEN DOOR GLASS or REPLACING OVEN DOOR GLASS,
You should be able to get all the imformatoin you need here.
Dec 02, 2010 | Zanussi Ovens
Lost instructions for plastic hinge jig
This is a home owner's jig for mortising **** hinges, It will not do production runs , that's for sure. It has to be layed out to start, but great for cutting one door. Do you have the router guide for it? Your hinge sticks out of the door on the side that it swings on, and it leaves about 1/4 inch of door on the other edge, the top and bottom are measured from the top and bottom of the door and you have to figure the thickness of the guide and make a test run on a scrap. The depth should be flush with the hinge. The standard way of measuring is, 7 from the top, 11 from the bottom and center in between the 2, they don't do that anymore, they just slap them in a pre-hung jig that mortises upside down, backwards, up, down, doesn't matter. all the same now days, only problem is you can't get a punch under the hinge to pop out the hinge pin if you have to. The card you have might have the dimensions on it for holding off the line. Hope this helps.
Oct 17, 2010 | Porter Cable 59370 Door Hinge Template
HI, i am looking for a guide bush to use in conjuction with a hinge jig, is there a special one that i need. Kind Regards Darren
I assume you are asking about a router guide bushing, although this question was filed under chain saws. The guide bushing size has to correspond to the bit size to get the right size cutout for the hinge template. Here's a set: http://www.grizzly.com/products/Brass-Bushing-10-pc-Set/H3134
Good luck, Al K
Aug 26, 2010 | Garden
I just got a used GE Profile Refridge and would like to change the door from left opening to right side opening. How would I do that?
Hi. Look carefully at the door and check to see that there are buttons on the side of the door opposite of the hinge. Those buttons conceal the alternate set of screw holes for the hinges. If there are no predrilled holes on the other side of the door then it is not reversible.
That said, If you do locate those buttons, unscrew the hinges from the door, have a helper there as the door will be heavy. Once the door is off, remove the hinges, then move them to the opposite side and reattach the door to the fridge. Put those buttons in the new open holes. J.
Jul 30, 2010 | GE Profile Stainless Bottom-Freezer...
I want to rout out for hinges with a freud trimmer will adding a block to the bottom of base plate work? will i be able to see the area i need to rout
You might be better off replacing the plastic base with a piece of 1/4" clear lexan (plexiglas). you'll be able to see through that.
Otherwise, you can make a simple jig that stops the trimmer at both ends (at the length of cut for the hinges) and controls the depth of cut by registering against the edge of the door. Make the jig base itself of 1/4' MDF or some such and longer than you think you'll need it to be so you have a way to clamp it or pin it down to the door.
If that sounds too complicated, try measuring the distance from the edge of the bit to the edge of the trimmer, in both directions, and marking the corresponding length away from the hinge position with a piece of blue masking tape or something, so you'll have an easily visible reference line when routing. You can mark it a little short and clean up the end of the cut with a sharp chisel.
Finally, run a test on a piece of scrap before you try to fit the hinge to your finished work.
Mar 12, 2009 | Freud FT750T Laminate Trimmer
Crafts & Hobbies Logo
169 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
