Child opened lid of 2081x micro spa controller and pulled all wires off pins can anybody pro vide photo of inside box
  • 32 Answers
You need more than a photo. That would be helpful but a circuit and wiring diagram would be better and you might get that from the manufacturer.
A bigger worry is a child being able to do this. I would be onto the manufacturer about the safety of the unit and what they can do to help. Perhaps suggest they need a product recall if it is that easy to tamper with by a child. ( that would put the cat in the pidgeons - but it could have been a lethal situation in mains voltage land)
Posted on Dec 14, 2014
LID LOCK SWITH ON ADMIRAL ATW4676BQ BROKEN, WHAT HAPPENS IF SWITCH IS BY PASSED BY CONNECTING WIRES SO ITS ON ALL THE TIME?
If its a micro switch it will not lock lid when running so machine will continue to run when lid is raised if it is bypassed.Most locks on washing machines are anti-child devices so might not be good idea if you have children.Machine will run and switch off when program finishes.
Feb 21, 2015 | Admiral Washing Machines
What does E5 mean on model EWIA16F5OEJ
An E5 error could mean that the child lock has been enabled or that the washer lid is open. The warning bell will have been ringing for a while. Close the lid if it is open. Press the On/Off button. Then press and hold the Super Turbo and EcoPower buttons until you hear a beep. This should toggle off the Child Lock.
If these steps do not resolve the problem, try unplugging the washer for a while. Otherwise, the control panel or lid lock are not properly communicating with the central control unit. Alternatively, the lid lock is not correctly activating when the washer is in use. You'll need to open the washer and find the diagnostic sheet. This will have a diagram of the wiring and the voltage or resistance that should be found between sections of the washer. Then check the wiring (including the insulation/individual conductors) and replace the appropriate parts. If you do not feel comfortable doing this, contact the appropriate service person. If the unit is still under warranty, contact Electrolux.
I hope this helps.
Jan 18, 2015 | Electrolux Washing Machines
I have a 2004 chevy Malibu would anyone happen to know Is there a way i can get Into my trunk from the inside of my car, my key stop working to the trunk and so did the trunk release button, all of my...
There is a relay in the rear fuse block for the trunk release. marked trunk relay #36. It is marked on the under side of the lid. If you knew how they worked you could open it by jumping pin 30 to pin 87 in fuse box. on the side of the relay is a diagram of what pins are what . This system uses an electronic control module called ( the BCM ) body control module .When you push the inside release button , that sends a signal to the BCM ,then the BCM activates the relay opening the trunk . Well that won't help ,you won't believe where the fuse box is ! Fuse Block - Rear
In the rear compartment, behind the left wheel well. You could jump the wire at the BCM that goes to the relay. Can't you pull down one of the rear seats to gain access ?
Dec 27, 2014 | 2004 Chevrolet Malibu
Wiring diagram for BlueRidge Spa
The wiring diagram for each spa is located on the inside panel of the control box.
Remove the side panel of your spa where the control box is located which is usually on the same side where the topside button is.
Once you remove the side panel you will see the control box.
Remove the front cover and on the inside of this cover is where the electrical diagram for all the wiring is found.
Rod
US Parts Center
Nov 02, 2013 | Pool & Spa
What does the Water Temp Shorted message mean as I can not fire up the heater for the spa
You have two sensors coming from the box at the equipment. One will be hanging just below the box. The other will go to a pipe and have a stainless steel clamp holding it in the pipe. This is the one you will need to replace.
After shutting the pump down remove the clamp and pull probe from pipe then follow the wire back inside the box. You will need a small screwdriver to remove wires and install wires from new one. Then just mount back in pipe.
Sep 19, 2010 | Jandy Aqualink Pda Ps4 Wireless Handheld...
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Need wire schematics -circuit panel box & heat element ARIES SPA
Did you check inside the cover of the control box. Most spa's have a schematic of their components there. Hope it is there.
May 11, 2009 | Home
Panel reads "water sensor opened"
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
Feb 01, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Lid Switch replacement
ok " unplug washer from wall , ( can not stress enough that there can be no electricity running to that machine)
depending on the washer most have screws on the back at top, you will have to take them out, ok so far , most lids have metal clips holding tops on , pry top up and it will pop loose.
got that far, now look at inside of the top where lid opens and you will see a small micro switch
two screws hold switch in place, electrical wires to switch are cliped on they will pull off
take micro switch to appliance parts store they will match it
take make and model of washer with you
screw in new micro switch and attach wires to switch , and snap
washer cover back on, attach screws to the back , and your all set.
see you can do it
Jan 06, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Washing Machines Logo
Top Washing Machines Experts
