Question about Frigidaire FKFH21F7HW Freezer
What is fecillities in using google+? - Frigidaire FKFH21F7HW Freezer
Our freezer is currently running at 41*. It has a symbol in the top left LCD display of a square with a horizontal V in it.
Google this: "testing compressor on refrigerator"
Should find a video to test the compressor with a multimeter--this is the one I used. The compressor on mine was fine but the switch was bad--two dollars and some change, free shipping. Although mine was on a compact fridge the same components are present in your model. If the compressor is bad and this is a several thousand dollar fridge I would suggest having a professional replace the compressor for you.
I hope this helps.
Feb 09, 2016 | Fagor QVF-2 QV Series Freezer
Why does my freezer not freeze?
Sound like a typical low freon Issue. Check out our articular on recharging residential refrigerators and freezers
On Time Appliance
If it Helped follow us on our Google plus page.
On Time Appliance Google
Jun 29, 2015 | Freezers
The freezer is to cold
I do assume this is in Celcius.
-20C is about the right level for a three-star freezer.
From Google:
  1. Domestic freezers have a star rating indicating the temperature they are designed to operate at. On the packaging of a frozen food there is guidance stating how long the food can be stored using freezers of a given star rating. As a guide here are some suggested maximum storage times at -18°C for a variety of foods."
Feb 12, 2015 | Freezers
What does C8 code mean on my upright freezer frigidaire
I cannot post URLs here, please go to Google and search using this: "frigidaire c8 code" and I think the appliance pros result is what you're looking for ;-)
Aug 18, 2014 | Freezers
The fridge(in my fridge/freezer has stopped
http://www.google.com/search?hl=en&rls=com.microsoft%3Aen-us&q=Cheltenham&as_q=refridgerator+repair+service&btnG=Search%C2%A0within%C2%A0results
go to this page on Google and look at what is available in your area, there are several businesses that do that kind of work.
Good Luck
Aug 07, 2009 | Freezers
Ice maker only fills the tray partially.
There is an adjustment, but first check your filters, including the one in the inlet of the control valve. To find the adjustment, take the cover off the front of the ice maker. On the side may be a little hole. Look for any 'increase' arrow or such. If not, use a small screwdriver to turn the adjustment a half turn and let it make a load of ice. If it gets smaller, go the other way, use small adjustments. If you can get the owner's manual, it will help a lot. Google your unit for one, you may be able to get it downloaded free from Whirlpool.
May 05, 2009 | Whirlpool Freezers
Changing the temperature on the Isa SP Freezer
It sounds like the control panel is in locked mode. Try pushing the button and holding for 3 to 5 seconds. One of the buttons should unlock doing that. It is set that way to keep kids from messing with the temperature.
If you can't get it google the Isa website and try to find your model or to download a manual.
May 04, 2009 | Freezers
Registration & Warranty?
I cannot find sitefor registration & warranty for my new microwave that i purchases. Iris
Jul 30, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Frigidaire FKFH21F7HW Freezer Logo
65 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
