Question about Uniden BC340CRS 100-Channel Clock Radio Scanner One Size
Scanner not scanning, says delay
I have pushed the scan button. I have unplugged the scanner and plugged it back in.
You need to turn up the squelch
delay is displayed when the squelch gets broken
so turn it up and scan or it will start to auto scan if you set it too auto
when a signal breaks then it stops .. and listens
you can set it to manual so when a signal is detected it will stop and listen too that frequency
if it says delay all the time then there is a problem
prob with the squelch cicruit or the control perhaps has had a knock
Posted on Dec 20, 2014
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
When I tell it to Scan, a window pops up and says, "Can't find the Scanner plug-in." I am sure I have it, but I just can't make it work. Any suggestions.
I suggest you first download the correct drivers and software or verify from the installation you have on your Mac that the software installed is the same version listed on the website. Having done this verification, kindly start the scanning software provided, turn on the scanner and then press scan. Sometimes, if there is a delay in the software response to a scanner's command or a delay from the scanner to a software's command then such messages show up.
Jan 02, 2010 | Apple Canon CanoScan N1220U Flatbed...
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
Hp f340 will not scan
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 18, 2009 | HP Deskjet F340 All-In-One InkJet Printer
RS Pro 2020 Scanner won't come out of scan mode, pad ineffective
If you mean a Bearcat 2020 radio, then that unit is ancient, and I'm amazed that it still works. If you're only monitoring one frequency, you can get a really cheap scanner to do that and replace the 2020.
Aug 01, 2009 | Radio Shack Pro-2018 Scanner
HP PCS 2510 Scanner module keeps running
Please follow my steps:
1. Make a ring, which is 5mm high and 1/3 cut so that it can be mounted at the far right end of the rail bar where the scanner module sliding back and forth. This can help get the none-stopping scanner out of the trap!
2. Do the Semi-Reset opreation. Then you can see the healing result!
Dec 22, 2008 | HP PSC 2510 All-In-One InkJet Printer
Hp psc 1350 printer scanner willnot scan when button is pushed on scan
http://www.tomshardware.com/forum/147103-45-printer-scanner-problem
Sep 05, 2008 | Office Equipment & Supplies
Scanner will not scan to certain programs
Try reinstallying the printer driver, but first remove the printer program.  Then, reinstall everything and try it again.  Unplug and plug the printer in.
Jan 28, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Awful noise
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (the plastic switch at the back of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Oct 16, 2007 | Epson Perfection 4180 Photo Flatbed...
Uniden BC340CRS 100-Channel Clock Radio Scanner One Size Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
