Question about Samsung Dishwashers
Samsung dms500tr comes up with e2 error there is water to the aqua valve
Checked water to the aqua valve
  • Samsung Master
  • 744 Answers
Hello Keith:
My name is Peter. I am a retired field service appliance technician.
You have a faulty fill hose and valve assembly.
Samsung dms500tr comes up with e2 error there is w - 25319861-tzrztvwj2hjvxoajtege33ry-3-1.jpg
Part Number 1673572 Cost: $136.00
It is located in the back of your dishwasher.
hwk1huedygosaaaaaelftksuqmcc
Posted on Dec 14, 2014
  • Keith Whitfield
    Keith Whitfield Dec 15, 2014
    Very helpful , as I suspected
  • Nick Steenson
    Nick Steenson Dec 21, 2014
    Hi Keith, how did you isolate the issue to the hose/valve? I have the same issue exactly with the same washer, is there just the one solenoid?
Is it possible to fit a new Aqua-Stop valve?
Yes, you just need to shut the main valve for the water to do the repair. The valve to do that should be right next to you meter in the house. Once it is off you need to open a couple faucets to let the water drain out then do your repair. After that turn the water back on and check for leaks.
Dec 24, 2014 | Dishwashers
AEG Favorit 44090i Dishwasher will not fill with water
There may be a filter after the aquastop pipe which is blocked. This is usually at the back of the inlet valve. Also, the inlet valve may no longer work.
Nov 07, 2014 | Dishwashers
Can i remove the aqua solinoid cut off valve from bosch dishwasher
the valve and wiring can be replaced you cannot remove it altogether as it wont be able to fill up, bosch aqua stops are normally powered solenoids that also double as the water inlet valve unlike most other aqua stops
Sep 27, 2014 | Bosch Dishwashers
Shower head keeps dripping water does not stop when turned off
I would look into possible failure of the solenoid valve assembly or the valve top assembly, which are parts 8 and 7 respectively, on the linked page. This site also has all the spare parts for sale.
You are viewing shower spares for Galaxy Aqua 2000 Aqua 2000
Aug 16, 2014 | Galaxy Aqua 2000
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aqua smart fault 49
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
Nov 26, 2012 | Fisher and Paykel Washing Machines
No water coming out of spout even though water enters system up to and beyond distribution valve.
this may sound stupid but i resently installed one and if then water pressure was not balanced between the hot and cold the unit would not work
Oct 30, 2011 | Aqua Brass Single lever faucet AQUA BRASS...
Freshwater not being taken by aqua-stop safety device
either water valve is bad or water line screen at valve is clogged. also, check if water is turn on..
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
886 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
