Question about Sigma 10-20mm f/4-5.6 EX DC HSM Autofocus Super Wide Angle Zoom Lens
My Sigma 10-20mm wide angle lens stopped adjusting when I focus. I'm still able to turn the focus ring, but the lens doesn't move and neither does the the thing that shows you the infinity bar. The lens is less than 4 months old, never been dropped, smashed, or had any water damage etc.
  • Harrie Dec 14, 2014
    Hi Kevin , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? On what camera are you using this lens? brand and model please
SOURCE: Sigma 18 -200 lens with D40x
This lens is NOT compatible as the body doesn't have a motor . £200 wasted
Posted on Jun 09, 2008
  • 39 Answers
SOURCE: sigma 24-70 2.8 EX DG AUTOFOCUS PROBLEM
I would send it into sigma. They are in NY,
They are really quick about checking things out and I have neverhad them charge me to look at a lens and tell me whats up. aot of times they will just fix it while it there is it looks like something is worn out from normal use.
its a great lens. Some would say its a slower focus. than the Canon brand and you do get what you pay for but its hard to spend as much on canon lenses as they want. :)
Hope that helps,
Caleb
Posted on Jul 02, 2008
SOURCE: sigma 70-300 mm lens wont focus
I was focusing to close to the subject & too much glare from a church window.
Posted on Sep 28, 2008
SOURCE: Front/Back Focus Problem at Sigma 30mm F1.4 Lens
Hello Abdul!
I recommend that you print this test chart: http://www.photo.net/learn/focustest/scale45.jpg
Just print it on an ordinary paper, then put it on a table, and take a picture at it from a 45 degree angle, using the center focusing point only, aimed at the thicker line in the middle. The numers are centimeters. Take the test picture at f/1.4. Make sure you have good light so you get a fast shutter time. If you have a tripod, mount the camera on the tripod prior to taking the test picture.
Then examine the picture in your computer, zoomed to 100%. Now it should be clear wheter you got back- or front focus, and how large the problem is.
Unfortunately, there is no way for you to adjust the camera and lens combination yourself, you will have to send/bring the camera to an autorized camera workshop. This is covered by the warranty.
Hope this helps!
Regards,
/Chris
Posted on Jan 19, 2009
  • 117 Answers
SOURCE: broken zoom ring on sigma telephoto lens
HI I need to no what fit the lens is
Posted on Aug 08, 2009
How can I adjust focus?
Turn the grey ring around the lens (where the light comes from) until the image is sharp.
Apr 11, 2016 | NEC VT595 Projector
Why does focus ring hit some type of stop?
Hi.
There is a problem inside your lens. It can be a flexible PCB (printed circuit board) or screw out of possition, so the focus moving parts can´t complete the range.
If the infinity focus gets at 3ft, there are also some optical group loose. That is the reason infinity position is located closer than it must be.
Send it to a Sigma Service.
Aug 21, 2015 | Cameras
Just bought this lens and the MACRO button doesn't move. is there something I have to do in order to switch it?
You need to zoom past 200mm and then switch it to the macro setting. You will see a mark on the focus ring that you must put the ring past on coming out of macro
May 27, 2011 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
I have an 18 - 200 mm sigma lens. problems are: 1. its lock does not work. the lens slides down to lower zoom magnification one raised to a diagonal position. 2. when fully extended, the thrid tube...
Send it in for repair
Sigma Canada
www.sigmacanada.ca/
SIGMA ART 24-35MM F2 DG HSM LENS. Lens details >> · More photos with this lens >>. SIGMA 24-70MM F2.8 IF EX DG HSM. Lens details >> · More photos ...
Lenses ' Sigma Corporation of America
https://www.sigmaphoto.com/lenses
Browse Sigma lenses including over 45 camera lenses available for most major mounts including Sigma, Canon, Nikon, Sony, Pentax and Micro Four Thirds ...‎Wide Angle Lenses · ‎Telephoto Lenses · ‎View All Lenses ' Sigma ... · ‎Art Lenses
Jul 27, 2017 | Sigma AF 28-200 Lens
Hi, i have the Sigma 70-200mm for Canon EF and the manual focus don't work. The HSM works fine and focuses perfect, but if you choose MF, you can't rotate the focus-ring. Many greetings from Germany! Kai
Hi, not sure if you still have this issue. I have just decided to look into it again, as I had a lot of focus problems with my Sigma 70-200mm HSM lens. Since there is no Sigma support here in Beijing, I took a look - and fixed it.
Here is what I did: On the front of the lens barrel is the rubberised focus ring. This can be removed (gently ply it away from the barrel by sticking a flat bit (or plastic letter opener) between the barrel and the rubber grip. It will come not entirely loose, so you need to work your way around the lens. Keep doing that until you moved it about half way forward. At this point two fixing screws become accessible on the barrel below.
In my case, one of the screws had come loose and that blocked the focus ring from turning, as the screw was blocking rotation in the access hole on the barrel.
Hope this helps others. Simple to fix, if you know how.
Nov 26, 2010 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
Disassembling a wide angle 50mm C lens for a RB 67
Are you a trained service tech? If not, step away from the lens and no one gets hurt. :-)
Aug 10, 2009 | Photography
See-through lens is blurry and does not reflect the change in focus when I adjust the wide angle lens on my digital rebel xti. What's the problem and how can I fix it?
Check the AF/MF switch over the lens left side. Should be on AF to let the camera focus by itself. If not, you have to manually focus using the focusing ring.
If the camera is in AF and still no focusing, considere to carry your camera for service.
Aug 01, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Hello Abdul!
Hope this helps!
Regards,
/Chris
Jan 05, 2009 | Sigma 30mm f/1.4 EX DC HSM for Sigma
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Losing focus
Usually this is a back focus problem; also called a flange back adjustment.  If the back focus adjustment is possible on this camera, zoom out wide - open iris all the way - and adjust focus and lock position.
Nov 06, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Sigma 10-20mm f/4-5.6 EX DC HSM Autofocus Super Wide Angle Zoom Lens Logo
Top Sigma Cameras Experts
Doberman
bhargav
Are you a Sigma Camera Expert? Answer questions, earn points and help others
