I want to activate my Sansai wireless mouse
Plugged in the usb inserted batteries into mouse turned on mouse
MJS_1
  • 150 Answers
SOURCE: cannot connect wireless keyboard and mouse
I am assuming that this is an INFRA-RED device, with
plug and play capability.
1) Make sure that the infra-red port is turned ON on your PC,
in the BIOS and in Windows (using control panel)
2) Make sure that the infrared driver is working:
My Computer ==> Right Click ==> Properties ==>
Hardware ==> Device manager ==> ....
Find the Infra-red device and check its status.
Some laptops have a mechanical switch witch controls all
wireless ports. If you shut-off the Wi-Fi, the blue-tooth and
the infra-red will also be disabled.
3) Check for tiny reset buttons on the keyboard, mouse and
the receiver. Press them repeatedly.
4) If the device is communicating, and infra-red ICON
should appear on you taskbar (RHS).
Right click the icon and make sure you enable IR
communications AND plug and play.
5) Make sure you have installed any drivers that came with
the keyboard, if any.
6) Again, make sure that infra-red communications are enabled
in the control panel.
5) Failing that, it is possible that the keyboard is defective,
or the infra-red port on your laptop is NFG, it would not
be the first time.
6) You may want to take your keyboard to a computer
shop, and ask the staff the try it with a different PC.
Alternately, try a different keyboard with the laptop.
Martin
Posted on May 08, 2008
SOURCE: Computer not recognizing Keyboard, only Mouse
I'm having the same problem. Mouse works great but the keyboard doesn't. I've uninstalled and reinstalled the software at least twice via remote desktop- done a hard reboot on the hardware (it's a Logitec wireless keyboard) - I've even tried installing it on another computer and the keyboard and mouse both work great! I just can't get it to work on my computer. The curious thing is that the side buttons (like sleep work) but it won't Ctrl Alt Del so I can login - what am I doing wrong? Are there settings that need to be changed?
Posted on May 10, 2008
EvilDeadAsh
SOURCE: Microsoft Wireless Notebook Optical Mouse Not Connecting
I have the same mouse and I had to install the intellipoint 6.1 software that came with it, and it worked flawlessly. Then I sold a few of them that I had and mixed up the dongles in the sales and now none of them work. Trying to figure out if I can force a recognition or are they proprietary to only one mouse. Go to microsoft and see if the intellipoint 6.1 is a download.
Posted on May 31, 2008
After reading on Microsoft about replacing the batteries, down loading drivers and "press the button on the receiver and the connect button the receiver" - I got frustrated and almost gave it flight. Then my wife stepped in and realized that there was a green reset button on the USB connector as well. (who knew?) SO.... you press the green light (which is a button) and release it.... should blink. Then go to THE MOUSE portion and press the connect button for 5 seconds or so.... and wala...... One mouse that plays again! This ones gonna cost me! :) I hope this one works for ya!
Posted on Oct 01, 2009
  • 23 Answers
SOURCE: I am just unale to activate the mpouse..my
Check underneath the mouse, there should be a small button, it should be the reset switch press and hold down for 3 to 5 seconds your laptop should be able to recognize it then.
Posted on Oct 21, 2009
How to install 2.4Ghz wireless mouse with USB receiver?
Insert the batteries into the mouse. Turn the mouse over, find the battery cover, and slide it off. Insert the appropriate batteries-usually two AAs.
  • The wireless receiver that plugs into the computer uses USB power, so it needs no batteries.
Connect the receiver to the computer. If your computer has a USB port (as most do), plug your receiver into an available port. There will also be a green adapter supplied, in the event that your system requires the use of the mouse port. Caution-don't try and force the mouse adapter into the keyboard port!
  • The mouse receiver has a USB plug (left), but can also plug into the mouse plug through the adapter it came with (right). If your receiver plugs into the USB port it should look like the left. If it plugs into the mouse plug it should look like the one on the right, only connected to the receiver.
Connect the mouse to the receiver. Place the mouse in close proximity to the receiver, and note the following:
  • The receiver should have a visible button that is easily pushable by the average human finger.
  • The mouse will usually have a very small reset button in a hole on the bottom that can be pushed by something like a pencil or paper clip.
  • Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
Find a permanent position the receiver. Place the receiver where it won't be far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk.
  • The furthest a wireless mouse can get away from the receiver and still function is about 9 feet (2.7 meters), so keep that in mind.
Test your new mouse.
  • If you plugged into the mouse port, restart your computer.
  • If you plugged it into the USB port you should be able to use it immediately.
  • When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Adjust your mouse settings. Use the control panel that came with your wireless mouse, or download the necessary software from the manufacturer's website. Adjust the settings so that the mouse performs as you require.
Oct 18, 2014 | Computers & Internet
Transit wireless mouse
Check the mouse to see if the battery/s are in correctly. + to + and _ to _. Make certain the USB receiver is inserted properly into an active USB port of the computer. Flip the switch on the mouse to ON. Should work!
Dec 22, 2013 | Office Equipment & Supplies
Mouse quit working
Logitech wireless mice operate in a slightly different technological sphere to wired mice.
Wireless mice need batteries, they need to be turned on and they need an interference-free radio environment.
One advantage of wireless mice is that they tend to function with laser or optical parts rather than a ball and wheels, so there are fewer moving parts to go wrong.
However, optical and laser wireless mice have considerations to take into account.
Change the batteries in the mouse if the mouse doesn't work.
Remove the battery cover and insert new batteries.
On the underside of the mouse could be plastic sticker with a phillips head screw (star) under it
Turn the Logitech wireless mouse on with the switch on the mouse.
Plug the USB receiver into a USB jack on the computer.
Try to use a free jack that's actually on the computer rather than one that's in a hub.
Test the jack first.
Try plugging in a printer and see if the printer is recognized--that way you know the USB jack is good.
USB jacks are notorious in that you frequently get a bad jack on a computer.
Turn off devices that are in the same frequency range as the mouse.
Logitech wireless mice operate at 2.4 GHz, which is in the same area as Wi-Fi routers and older cordless phones.
Start by turning those devices off and see if you can eliminate any causes of interference.
Test with wireless speakers too, then computer power supplies, monitors, cellular telephones and garage door openers.
Place the mouse on a flat surface that doesn't reflect. Avoid metal surfaces too.
Apr 21, 2013 | Logitech Cordless Mouse
How to connect to laptop
Using a wireless mouse with a laptop is a convenient way to avoid using the laptop's built in mouse.
Moreover, even if you use an external mouse, carrying a wireless mouse is easier than the wired version.
Here is how to use a wireless mouse with a laptop.
Ensure that your laptop is compatible with a wireless mouse.
Most wireless mice use Bluetooth technology.
Any Bluetooth enabled laptop can connect to a Bluetooth wireless mouse.
Unpack your mouse and insert batteries to the battery chamber.
While doing so, make sure that the positive side of the battery is inserted into the positive niche in the compartment.
Place the mouse in a way that makes it easy for you to use and less stressful for your fingers.
Use a wireless receiver if your laptop does not have an built in wireless receiver (either Bluetooth or 802.11b).
It should be kept at least eight inches away from the laptop or any other object that would cause any interference.
Insert the drivers, if any, for the mouse to function properly.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop.
If you do not have any free USB ports, simply use an external USB hub for more ports.
Apr 20, 2013 | HP Wireless Optical Mouse
New mouse does not work.
How does it Connect to your Computer? Probably has a USB Drive that you are suppose to plug in
Try turning your Batteries around (My Microsoft Mouse had the same issue and when I turned it around, everything started to work...
Apr 11, 2013 | Sakar Iconcepts Iconcept M01728 Wireless...
How do i get my wireless technika mouse wm110pk to connect to my laptop?
Insert the USB dongle that came with your technika wireless mouse into a USB computer port on your machine.
This dongle, which resembles a regular flash drive in appearance, can be plugged into any available USB port.
Once inserted, it immediately turns on.
Insert the required amount of batteries (typically two AA batteries, though it changes depending on the model) into the compartment on the bottom of your HP wireless mouse.
Flip the "ON" switch on the bottom of your technika wireless mouse.
Press the "Sync" button on the bottom of your technika wireless mouse.
The mouse will now sync with your computer and will be immediately usable.
hope this helps
i have read some good and bad reviews on this mouse one stated the wireles stopped working several times and it had to be replaced
Oct 12, 2012 | Computers & Internet
How do I connect a microsoft wireless moblie mouse 3000 to my laptop?
Press the button on the back of the mouse to free the battery cover on top.
Remove the battery cover and put the supplied AA battery into the mouse.
Replace the battery cover.
Insert the wireless USB dongle into a USB port on the laptop or desktop computer.
Move the mouse and watch your computer screen.
Confirm that the mouse is connected by making the cursor move.
Hope this helps
Sep 26, 2012 | Microsoft Wireless Mobile Mouse 3000
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
I bought a gateway zx series computer 3 weeks ago. the wireless keyboard and mouse that came with it has stopped working for no apparent reason. the computer says that it doesn't recognize the device. i...
hi Karnarc.
How do I troubleshoot my Gateway wireless keyboard and mouse? How do I troubleshoot my wireless keyboard and mouse?
If you are experiencing issues with your wireless keyboard and mouse not working properly, perform the following steps to troubleshoot the wireless keyboard and mouse.
  1. Make sure the USB connector from the receiver is properly plugged into a USB port on the computer. Some systems ship with the receiver already preinstalled in the unit itself. Please check your mouse to see if there is a receiver inside of the battery compartment door.
  2. Make sure wireless keyboard is not on a metallic surface.
  3. Ensure that the receiver is 8-inches from other electrical devices.
  4. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
  5. Check the batteries in the keyboard and mouse to make sure they are installed correctly.
  6. Test the batteries to ensure that they still have a charge.
  7. Verify the On/Off switch on the keyboard and mouse are switched to On.
  8. Some receivers, keyboards, and mice may have a connect button. If so, follow the steps below:
    1. Plug the USB receiver into a USB port on your computer.
    2. Press the connect button on top of the receiver and the button will blink.
    3. Press the connect button on the bottom of the keyboard to activate the wireless connection.
    4. Press the connect button on top of the receiver and the button will blink.
    5. Press the connect button on the bottom of the mouse to activate the wireless connection.
Dec 03, 2017 | Gateway Computers & Internet
Activating COT2 wireless mouse
Your ACME COT2 wireless mouse must have come in two pieces, the USB connector the mouse itself.
Insert the USB connector of your wireless mouse to your Toshiba Satellite and press simultaneously the button in your USB connector and the button in the wireless mouse. This is done in order to pair the mouse to the USB connector.
Jan 05, 2009 | Computers & Internet
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
