Question about Sunbeam Twin Heated Blanket Navy Blue 006410-030-556
How do I reset overheat protection on silentnight blanket
I cannot get the f to come off so I can get the blanket on
Sometimes unplugging the blanket from the wall plug causes it to "reset"
Feb 27, 2015 | Sunbeam Fleece Throw Electric Heated...
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Se My blanket is blinking F2 and I can't set the controls
To reset the control:
1) Unplug the blanket from the wall outlet.
2) Check that the control is well connected to the module. (Disconnect and re-connect it).
3) Plug the power cord into the wall outlet.
4) Set the control to "on".
Try 1-4 three times. If the blanket still does not operate, disconnect the power cord and contact Sunbeam Customer Care at 1-(800) 892-7684.
Oct 07, 2014 | Sunbeam Electric Blanket - queen
Cant find the flag tag to reset my electric blanket control
Oct 05, 2014 | Sunbeam Electric Blanket - queen
What is an emergency thermal blanket? Do I need one for my tent?
Emergency thermal blankets are insulated blankets that give protection in all-weather condition's. If you are going camping in your backyard then you don't need to get one, but if you are doing a proper camping trip and want to be well equipped, it's a sensible precaution to take one with you.
Sep 10, 2012 | Camping, Backpacking & Hiking
How to reset my sony mhc-gs100??? it keep saying power protect...
Your stereo went into protect mode to prevent complete failure of the amplifier inside that radio. Most of the time this happens from playing the stereo real loud for a real long time and it overheats. Most of the time disconnecting the receiver/stereo and letting it cool all the way down or at least 5 minutes and then reconnecting it to the power source will reset the protection mode. You want to make sure you are keeping the radio cool. Don't stack anything on top of it and try keeping a small fan blowing on it to expedite the heat out from the unit. Also turning it down every now and then to let everything cool down a bit will help prevent it from going into protection mode as well.
Mar 24, 2011 | Sony MHC-GS100 CD Shelf System
The HT-R510 unit's overheat protection kicked in
Hey there..Sorry.When the amps are over powered they blow the main circuit and short causing the amp to turn on the right back off to protect mode.That you will have to send in to get fix..Look behind the amp and see if theres any wires touching or grounding out.My favorite amps are from onkyo and believe me i've done this a few times to 5 aps I've had.So I up graded to the tx sr 906 It rocks and will blow every speaker I have before the amp will go..Hope this helps you and good luck..Have a great day...
Apr 02, 2009 | Audio Players & Recorders
Electric blanket controller light blinking
i had the same problem , i believe it was caused by unplugging the blanket plug while it was in the on position , i unplugged it from the wall and it like reset itself , worked for me.
Sep 20, 2008 | Heating & Cooling
OVERHEAT PROTECTION
The thermal protection would have reset when the amp cooled down. When cool, if it still goes into protection when it powers up, there are likely blown output transistors. To be sure it's not a wiring problem, disconnect the speaker wires 'from the terminal block of the amp' and disconnect the RCA cables from it. If it still goes into protection, the output transistors are almost certainly shorted.
Sep 09, 2007 | American Pro VS-2043 Car Audio Amplifier
Sunbeam Twin Heated Blanket Navy Blue 006410-030-556 Logo
41 people viewed this question
Top Sunbeam Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
