How to escape from this problem protect 05 - Audio Players & Recorders
Alternator wire diagram
I'm afraid not. The alternators as well as the trucks are wired differently.
The black yellow wire on both models goes to the fuse box, but on the 2005 model with the extra wire, the gray orange and brown white wires goe to the engine computer which acts as the voltage regulator. The 2003 computer would not have provisions for those circuits.
Jul 22, 2013 | 2003 Ford Escape
Will a radio from a 03 ford explorer fit in a 05 ford escape? The 05 escape has the pins you need to take it out. The explorer doesn't, that has two bolts. Just wondering if it will or could work.
They have kits to retrofit radios. Another thing that will cost is having the radio reprogrammed. Everything has theft lock on them now days. You would be better off to get a aftermarket stereo
Feb 27, 2011 | 2005 Ford Escape
What size socket fits the front axle nut on a 2003 ford escape
For a 2002 Escape the hub nut is 32 mm. The torque specification is around 175 ft.-lbs.
Feb 22, 2011 | 2003 Ford Escape
05 escape obd2 code po193 whats wrong?
u have either excessive fuel pressure or a defective fuel pressure regulator or a defective pressure sensor in the fuel rail..
Jan 26, 2010 | 2005 Ford Escape
'05 Escape, Rear hatch does not latch securely, how do I adjust it?
the bumpers could be worn from a lot of use but on a 05 i doubt it. there should be adjustment on the reciever 'post, joe
Aug 25, 2008 | 2005 Ford Escape
53 people viewed this question
 Grubhead
Grubhead
