Question about Cameras
How come my printer kicks back my paper then says I'm out of paper
Reentering my paper more than once
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Clean your rollers on the feeder and make sure there is not to much paper also on the margins make sure your tabs that hold the paper in alignment are pressed against the paper....Hope this helped
Posted on Dec 13, 2014
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
'paper jam' message - Printer not working!!
Clear all paper jams from the front and the back areas inside the printer. Then, turn off and restart. It should reset itself.
Aug 10, 2017 | Samsung SCX 4200 All-In-One Laser Printer
Unable to set custom paper size
Since you haven't provided the make and model of the printer, my response will be limited.
I suggest that you let Microsoft examine your Win 7 online. It can be done in three easy clicks and you'll have a complete diagnosis. I suspect that your drivers need to be updated. You can diagnose the problem by CLICKING HERE
Apr 30, 2012 | Office Equipment & Supplies
Jammed paper
You might need to update your drivers. If this doesn't help, there might be some loose gear inside the feeder . Try checking if there are also objects stuck.
Apr 17, 2012 | Epson Stylus R265 InkJet Photo Printer
Problem 391 on OKI C5200 printer but no paper jam was found.
Open the top. Pull on the top of the toner cartridge (don't release the latch, just pull it up). It will come up with the toner drum assembly attached. You will probably see another paper stuck there which can't be seen when the drums are installed. Also, open the back door and look for paper that might be stuck. But usually, when you've checked everywhere else, the remaining paper is flat under the toner drums. Once you get it out, just click the drum/toner assemblies back in place (careful not to let the green drum touch anything while it's out of the printer.
Mar 06, 2012 | OKI C5200n Laser Printer
Its always saying that BACK COVER IS OPEN we already check it for many times but its intact and in correct possition. and also the paper wont feed the machine.
Hi there!!
The message that you're getting means that either the back cover is not closed securely or there's a jammed paper inside. Here's what you can do to clear the message:
-Please unplug the fax machine for your safety -Open the front cover -Remove the toner & drum assembly (theres a handle in the center of the drum/toner assembly, just pull it towards you. -Remove any pieces of paper stuck or the jammed paper -Remove the toner from the drum and check for any other pieces of paper stuck -Once everything is clear -Reinstall the toner back into the drum and the drum & toner assembly to the fax machine. You should hear it click into place once installed correctly -Close the front cover & plug in the power cord. That should clear the message
Hope this helps, Thumbs up if it does, thanks!
May 08, 2011 | Brother IntelliFax-2820 Laser Fax
Cannot get motorola 2210 out of bridge mode
You'll need to reset the modem. Take a paper clip or something small and push in the reset button on the back. Hold for 15 seconds. You'll need to reenter you UID & PWD when you log in.
Jun 10, 2009 | Computers & Internet
We have a Cannon Pixar ip4300 I accidently kicked the paper tray door once when it was open and now everytime we try to use the printer we get an error message about that we need open the paper tray d
I think your on the right track, youv'e probably dislodged or broken a micro switch, screws are mostly underneath, be careful this could turn into a Mecano Nightmare! Good Luck the Yeti
May 20, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
