Question about Danby Dishwashers
I have a danby model ddw1899wp-1. I just ordered a replacement caster wheel and can't remove the old one to put on the new one??
SOURCE: what is the funnel thing
The "funnel thing" is exactly what it looks like- a funnel. It's for adding the salt to the water softener located on the "floor" of the dishwasher:)
Posted on Dec 16, 2010
  • 4 Answers
SOURCE: Casters (cheap plastic wheels) have broken. I have
FAST and EASY SOLUTION that WORKS!:
If a wheel breaks
1) use pliers to pull whats left of the plastic wheel off the metal fixed shaft
2) buy replacement wheel from Home Depot
Shepherd 2 in. Twin-Wheel Stem Casters 2 Pack
http://www.homedepot.com/h_d1/N-5yc1v/R-100082918/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
3) use pliers one again to pull the shaft of out the Home Depot plastic wheel (takes to works)
4) attached the new plastic wheel to the Dishwasher's metal wheel shaft (if the wheel is loose, add some tape to the metal shaft to make it tighter fix)
5) your done, simple as ABC123
6) clean your dishes and smile :-)
Posted on May 10, 2011
caroldon
  • 17129 Answers
SOURCE: i have a ddw1899wp danby i have a green power
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Posted on Nov 05, 2011
ercupa190
  • 12223 Answers
SOURCE: error code #4 on ddw1899wp danby dishwasher
see this possibles causes:
you must read your instruction manual and go to the section troubleshooting for fix it the error codes. If you do not have go www.fitness.manualsonline.com or www. retrevo.com
God bless you
Posted on May 26, 2012
SOURCE: My portable danby is stuck on the Drain cycle
Not sure what is meant "bottom front panel" but I have a similar problem. Looked for standing water, removed it, machine seems to work. Mmmmm.... now looking for why this is happening. If it is a "leak" any insite as to what is leaking?
Thanks for your solution, very helpful.
Posted on Jul 24, 2012
Trying to find out Danby DDW1899WP's salt capacity?
don't fill it more than half, you want to see that the unit is consuming the salt, but filling it all the way sometimes leads to a hollow pathway in the dissolved salt under the pile, the water channels through the path and your softener will be sounding like it is working, but doing very little. Be aware that there are different types of salt depending on your water type... there are rust removers, etc... I don't see how importing salt from Finland is going to be much more efficient than buying the salt at ACE hardware- whatever floats your boat.
Nov 21, 2016 | Danby Dishwashers
I need a manual for a Danby Model DDW1899WP-1 portable dishwasher
Danby has the manual for the DDW1899WP-1 on the product information site: https://www.danby.com/en-us/products/kitchen-en-us/ddw1899wp-1/ . Look in the right hand column as you scroll down. The direct link to the Owner's Manual is currently: https://www.danby.com/wp-content/uploads/2016/04/DDW1899WP-1_EFOM_201504212.pdf .
I hope this helps.
Oct 15, 2016 | Danby 18 inch Portable Dishwasher in...
Danby dishwasher faucet adapter
Yes, I have a new portable dishwasher and no adapter, not sure what size to get. model DDW1899WP-1
Jun 25, 2014 | Danby DDW497W 22 in. Countertop Dishwasher
Caster broken
Some caster wheels are a press fit on an axle. That's why they frequently fall off.
Feb 19, 2014 | Goldstar DH304 Dehumidifier
Where can i get a set of wheels for my five gallon brute vaccuum?
http://www.shopvac.com/shopvac-accessories/Products/420-63-96.aspx
emailthispage.gif printthispage.gif 1" Dual Wheel Caster (Set of 4 6774200 casters with retainers) Catalog No. 420-63-96
Four (4) casters. Set of 4 Replacement Caster Wheels with retainers. This item is the replacement for the plastic, non-hooded casters shown. These casters you will receive are an upgraded dual hooded caster that are a perfect replacement but offer superior performance.
Four (4) casters. Discontinued. Order this item and we will send you an upgraded, superior dual hooded set of casters. A = 1-12/16" B = 1/4" C = 1-9/16" D = 3-7/16"
You can also look at your local Lowe's who sometimes carry a generic wheel.
Mar 07, 2011 | Shop Vac Brute 5 Gallon Bagged Canister...
take bottom front panel off to expose bottom tray and you will probably find it full of water. disconnect from electricity and mop water out and machine should work. if fault reoccurs then you have a leak
Sep 25, 2008 | Danby DDW1805W Designer Series...
Broken casters (wheels)
This is definitely something that you can do yourself. Remove the back of the dishwasher and the front kickplate. This will give you access to the wheels. The wheels are held in place with a U shaped clip. Remove the clip and the wheel will come out. replace with the new wheel.
This happened with my Danby DDW1805 and I fixed it myself. I used two step stools at the side of the dishwasher to raise it off of the floor.
Aug 28, 2006 | Danby DDW1805W Designer Series...
Dishwashers Logo
103 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
