Question about DeLonghi Magnifica Coffee Makers & Espresso Machines
My Delonghi Magnifica is not descaling. I immediately goes into rinsing mode and doesn't rinse! No hot water comes from the spout. When the Hot Water button is pressed, it makes some whirring
I was trying to descale the machine but nothing is happening. The machine goes into rinsing mode immediately afterwards, but does not rinse. It is not behaving the way it should according to the manual.
  • 5 Answers
Try switching of machine. wait a minute and restart. see if that has helped to reset the software
Posted on Dec 13, 2014
  • Bill Ruskin
    Bill Ruskin May 25, 2015
    The identical "failure to descale" occurred on my DeLonghi Gran Dama ie.immediately going into rinse mode and no water coming out of spout. What is the solution?
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
How to descale the DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
put your descale mixture in 1 litre water in your water tank on coffee machine set machine on descale then after finish, put 1 litre clean water for rinsing. the all ready for coffee.
Jun 14, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
My maker keeps on saying descale. but how do i do it.
17.3 Descale
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the message:
DESCALE
flashes on the display, you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the P button (the light over the button comes on) then press the button repeatedly until the
appliance displays:
DESCALE No
• Press the button (corresponding to the SET symbol flashing on the display) and the appliance will
display:
DESCALE YES
• Press the OK button to start the descale programme.
• Empty the tank and pour in the contents of one bottle (125 ml) of DURGOL descaler plus one litre of
water.
For subsequent descaling, use descaler of the same type and brand as supplied (available from technical
service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
34 C o l l e c t i o n
• press the OK button.Descaler runs off from the hot water spout into the container below.
The appliance displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
Oct 22, 2013 | DeLonghi Prima Donna Avante ESAM6700...
Flashing coffee and descale
Identical problem, descale light doesn't extinguish despite descaling correctly. Coffee continues to be made as normal though ! Any solution ideas please ?
Mar 04, 2013 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
How to discale the unit
Delonghi EAM, ESAM, ECAM, Nespresso
When the appliance displays the message:
DESCALE
Proceed as follows:
• press the button (the light over the button comes on) then press the button repeatedly until
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
RISRINSING COMPLETE PRESS OK
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Jan 01, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Descale
DESCALE
Proceed as follows:
DESCALE No
DESCALE Yes
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Descaling coffee makes esam4200
100ml of descaler per tank of water. then they say 1 rinse, but I have to rinse 5 times to not taste the descaler anymore.
Jul 21, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Need descaling instructions for EAM 4500 auto espresso machine
use 1/4 cup of vinegar and fill pot with cold water, run through machine
Aug 01, 2009 | Coffee Makers & Espresso Machines
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
428 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
