Question about Maytag Refrigerators
Change light bulb in Maytag MAN1956GE Refrigerator. Can't loosen bulb. Can't remove plastic "cage" around bulb.
Squeeze cage, wiggle to loosen bulb. No luck
  • Maytag Master
  • 744 Answers
Hello Jane;
My name is Peter. I am a retired field service refrigeration technician.
What you have provided is the standard manual number not the model number. The model number is on a label on the inside wall of your fresh food section near the top.
You may have a single screw holding the light cover on.
Note; the bulbs in a refrigerator like all of you appliances is specially designed for the service. They are a little expensive $8.00 - $10.00 each. Some food markets carry them. If not Lowe's or Home Depot.
Go into the following link put in your model number and a diagram will appear to help you.
Water Filters Lawn Garden Appliance Parts
Posted on Dec 14, 2014
  • 306 Answers
SOURCE: how to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Posted on Jan 01, 2009
omaharox
  • 161 Answers
SOURCE: How do I open the plastic shield covering the
Use a butter knife and insert it in the slot between the cover and white plastic holder and pull the knife lightly twords you.
Do this on both sides and the cover should come out.
Use 40W bulbs for replacement.
Posted on Jan 17, 2010
  • 31 Answers
SOURCE: How to change light bulb. Can't seem to get cage off
Cover should unclip in a downward direction.
Posted on Mar 04, 2010
ricsindy
  • 53 Answers
SOURCE: How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Posted on Mar 09, 2010
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
Removing head light bulb how to unlock bulb .from holder.
Hi
the bulb should have a metal clasp over the back of it, you squeeze this together then you will feel it click, then you open it like a door, one side is hinged so it only opens one way. the metal clasp is often very thing metal wire shaped like a small round cage over the bulb, they have 2 loops on the end of each none hinged side, these loops slot into 2 small hooks that remain on the back of the headlamp.
Hope that helps, do you need more info?
Regards
Dan
Dec 28, 2010 | 2003 Ford Windstar
How to change a headlight bulb on a 2002 Harley Davidson Dyna Wide Glide
REMOVAL
Do not ever touch the quartz bulb with your fingers as fingerprints will etch the glass and cause the bulb to fail prematurely.
FXD, FXDL, FXDX Models
Loosen the trim ring clamp screw and nut, remove the trim ring, pull the connector block from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to unhook and release them from the from notches in the headlamp assembly, pivot the wire retaining clip away from the bulb aqnd then remove the bulb from the headlamp assembly.
FXDWG, FXDXT Models
Loosen the trim ring clamp screw and remove the trim ring, pull the wiring connector from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to unhook and release them from the notches in the headlamp assembly, pivot the wire retaining clip away from the bulb and remove the bulb from the headlamp assembly.
INSTALLATION
Install a new bulb and assemble the headlamp components in the reverse of the removal process. Align the headlight when it is fully installed. When reassembling the headlamp ensure that the slots and tabs in the headlamp, adapter ring, and trim ring are aligned.
Jul 12, 2010 | 2002 Harley Davidson FXDWG Dyna Wide Glide
Ask proxima C 180 lamp replacement
its just sitting in a plastic cage---- wiggle and pull at the same time
Apr 09, 2010 | Office Equipment & Supplies
The left brake light and tail light will not come on. The bulbs seem to be ok as well as the fuse.
Try to wiggle the connector with the lights on. If they flash on while wiggling the connector, disconnect it and squeeze the plastic with a pair of plyers to tighten the metal connectors. If this doesn't help, check the taillight circuit board (if this is a wagon, this won't work).
Apr 03, 2010 | 1987 Volvo 240
Remove heater blower birdcage
if your trying to change the squirrel cage of the blower motor,
in the center of the cage,where the motor shaft comes up thru it,there is a pinch clip that you need to squeeze together and pull off,then pull cage of shaft
Dec 10, 2009 | 1999 GMC Jimmy
Trying to replace rear turn signal light by following manual...which I can usually do..however we can't seem to get past removing the 2 screws...it has proven very difficult to find the clips that it says...
They are on a rail, after removing the screws it should slide towards you. Since it just wiggles, there are small plastic studs that keep it in place. I you need to pull it towards the front of the car or 90deg out from the front of the van.
Aug 20, 2009 | Chevrolet Express Cars & Trucks
Burnt out Parking light on driver's side
It helps to know what year make and model you are driving. look under the hood and look down at the back side of the parking / blinker light. Sometimes you have a twist style plugin similar to a child proof cap on the top of a medicine bottle that goes into the back side of the light and then there are some that you have (2) screws into the face of the amber lens that you need to remove to be able to access the bulb or to be able to pull the whole light assembly out from the front of the car to expose the plug in the back of the light housing. There may be squeeze tabs on the side of the plug that you have to squeeze before twisting. Finally there are some plugs that you simply wiggle as you pull from the back of the light assembly that are pressed in with a rubber boot (seal) around the plug.
Good Luck. Hope this helped.
Apr 04, 2009 | 1997 Jeep Grand Cherokee
How to change headlamp in 1997 volvo 850
Hmmm...
Changing a headlamp on an 850 is so simple I almost thought you were joking... Pop the hood, and behind the lights you'll see a round cap that you can twist to remove, giving you access to the bulbs. The bulbs themselves are secured by some small pins that you squeeze in order for them to loosen, as well as the plug with wires that supplies the bulbs with electricity. It's preferable to remove the plug before the pins.
Mar 16, 2009 | 1997 Volvo 850
Replacing the license plate light
Their is a plastic lens covering the licence plate bulb. I can be removed by using a flat-tipped screwdriver covered by a shop towel (or tape) on the right side of the lens. It should pop off where you can access the bulb.
Good Luck!
Sep 16, 2008 | 2004 Honda Odyssey
Changing tailight bulb
First open the rear hatch. Look just inside the door next to the rear lens assembly. There should be 2 screws that need to be removed. This should loosen up the assembly. Next gently pull the assembly back and out to you.Do not pull to hard or to far, you are still connected with wire. Next, squeeze the retainer and twist the bulb assembly ccw. You are there. Reverse it to put it back. Good luck.
Aug 26, 2008 | 2006 Mercury Mountaineer
Refrigerators Logo
217 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
