Question about Roomba iRobot 630 Vacuum Cleaning Robot
Roomba 630 dead or other issue?
I just bought my Roomba today and I cam home, took the battery protection out and plugged it in to charge for the first 16 hours. The yellow light came on and I left it alone to charge. After 15 minutes The light went off, no button responds in no way, pressed or held pressed. If I try to charge it by station it shows that it's charging but it doesn't do anything. What's happening? Can I do anything about it or is it dead? I wanted to be sure I can't do anything before I throw it back to where it came from.
    Top Expert:
  • Roomba Master
  • 78,267 Answers
Take it back.
Posted on May 19, 2017
4 Suggested Answers
  • 17 Answers
SOURCE: roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Posted on Jan 10, 2009
  • 8 Answers
SOURCE: can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Posted on Jun 23, 2009
arky241640
  • 778 Answers
SOURCE: Roomba 630 dead or other issue?
On your operators manual there is a number u can call for cust support. If not then take back for swap out.
Posted on Dec 12, 2014
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
Dec 12, 2014 | Roomba iRobot 630 Vacuum Cleaning Robot
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
I noticed my run time was getting shorter and shorter, within the first 6 months. I checked my charger and base with a V.O.M. okay. About 4.4 volts on the base about 14 volts on the direct line. I bought...
To extend Roomba's battery life and keep Roomba cleaning at peak performance: • Always keep Roomba plugged in when not in use. • Recharge Roomba as soon as possible. Waiting several days to recharge Roomba can damage the battery. • For storage off the charger, remove the battery from Roomba and store in a cool, dry place. • Blue or black batteries should be stored after Roomba has been used. • Yellow batteries should be stored after being fully charged.
16-Hour Refresh Charge If Roomba has been left off the charger for an extended period, Roomba will initiate a special 16-hour charge cycle. This extensive charge refreshes Roomba's battery and extends the battery life. While charging, Roomba's "Clean" button will pulse quickly. Note: For best results, do not interrupt this Refresh Charge.
Happy Holidays The FixYa Team
Dec 18, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba stopped after 45 minutes. does not move. manually placed on docking station...nothing
Sounds like something's dead either with the roomba or the charging station or power supply. Does it charge up if you plug the power supply directly into the roomba, instead of into the charging station? If not, you'll probably have to return it to the place you bought it.
Aug 27, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba Discovery series wont charge
You should check the dock if there is an output voltage at the charging terminals.
Jan 02, 2018 | iRobot Roomba Discovery SE Bagless Robotic...
My Roomba will not charge, the light on the charger is on and when you plug in the roomba the light goes out and nothing happens. Can anyone help. It is a Discovery Model 4210
Are you using the home base or are you plugging the charger directly into the Roomba? If you are using the base, give plugging directly into the unit a try.
You might also try resetting the battery. With the battery out of the unit, press and hold the power button for 30 seconds or so. After this is done, plug the charger directly into the unit, and let it charge for 3 days (no kidding, 3 days). After that, if you still have issues, it might be time for a new battery, or time to send the little guy in for repair.
Sep 30, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba 4108 does not charge
Dec 12, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba iRobot 630 Vacuum Cleaning Robot Logo
59 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
