No secondary voltage - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Dec 13, 2014
Schematic malibu 8100-9120-01
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
I don't think they post schematic for the transformer
But generally, the primary coil receives 120Volt AC input from household electrical outlet
And the secondary coil produces 12Volt AC output for the low voltage lights.
The 'coil' is a coil of insulated wire wrapped around a metal core. Two coils set side by side create a transformer... when primary is energized, the secondary responds to the magnetic field caused by primary core... resulting in a current that flows on the secondary coil.
Output voltage on secondary coil is determined by the number of wraps and diameter of wire.
Some transformers offer a choice of secondary output... Kichler for example... you can select 12-13-14-15 Volt AC output
This is achieved by the way the secondary coil is wrapped.... for less voltage a wire is tapped at one point on the coil... for more voltage, a wire is tapped at another point on coil. This gives the user several wire choices to connect the lights.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 09, 2014 | Intermatic Malibu 300W Power Pack...
I replaced my secondary air check valve on my 2001 chevy tahoe but code 1416 still comes up. what else can i check
here is what i found on p1416.
P1416 Chevrolet
P1416 Chevrolet - Secondary Air Injection System Bank 2
Possible causes
- Faulty Secondary Air Injection (AIR) pump
- Secondary Air Injection check valve bank 2
- Secondary Air Injection (AIR) pump electrical circuit fault
- Blocked Secondary Air Injection (AIR) system
When is the code detected?
The P1416 code is set when no O2 sensor voltage change is detected by the Engine Control Module (ECM).
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
P1416 Chevrolet Description
An Secondary Air Injection (AIR) pump is used on this vehicle to lower tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump. The Powertrain Control Module (PCM) monitors the HO2S voltages to diagnose the AIR system. During the AIR test the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
Jan 23, 2014 | 2001 Chevrolet Tahoe
I want to know what is the secondary voltage of transformer inside PC control panel ?
You have not mentioned the details of the machine in question. All you need is to check on the LT ( low voltage side ) of the transformer to find the secondary voltage which will be about 20 to 30 % less than the DC voltage shown on the capacitor on the board. If there are more windings then you can get the primary rewound without any changes to the secondary that must help to solve.
Jan 14, 2013 | Washing Machines
Error code p2258
Hope this helps
Trouble Code: P2258
Secondary Air Injection (AIR) System Control A Circuit High
Possible Causes:
AIR relay fault - stuck closed Secondary AIR pump fault - circuit open in motor Open ground to secondary AIR pump Open AIR monitor circuit between the secondary AIR pump and the PCM Short to voltage in the AIR relay to secondary AIR pump voltage circuit
Oct 15, 2012 | 2004 Ford Focus
Samsung tv no led indicatior glow.. voltage regulator 3s125r have a primary voltage and secondary no voltage
if no secondary voltage at the regulator that was mean the regulator is bad which need replacement.the output supply will not pass through to the other circuit which turn on the tv.
Aug 17, 2012 | Symphonic ST420FF 20" TV
How to test for bad transformer
  1. To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
  2. You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
  3. Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
  4. To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
Dec 16, 2011 | Emerson LC320EM8 32 in. LCD TV
Hi i m sanjay i m having sony colour television kv-2782me7 i found some problem in power supply section i m geting low voltages frm secondary output i want 135 ,25 ,8 , and -33dc voltages bt i m geting...
there is a possibility of a shorted turn of the flyback transformer. To test. short B-E together on the horizontal output transistor and connect 60W globe across C-E. measure voltage across lamp - if it comes up to 135v then you have a short either in the horizontal circuit or secondary circuit off the flyback transformer or even the transformer itself.
Aug 10, 2010 | Televison & Video
I have a Battery Tender 12v 1.25a battery
remember secondary voltage is AC like the primary voltage, only its reduced typically 120vac primary and 12 or 18vac secondary then the ac secondary is rectified using a bridge rectifier to get the 12vdc then a filter circuit is applied to remove any electrical noise.. any way the problem is with the dc voltage side of the circuit and unless you know how to troubleshoot the circuit you will not be able to repair it. my experience says it might be a bad bridge rectifier.
Dec 29, 2009 | Battery Tender Measuring Tools & Sensors
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
