Question about Reebok Flywheel For The Nordictrack Cxt 970 Elliptical Model Number
I have a Nordic Track X9I. When I turn it on, the blue IFit screen appears, console starts to boot and then goes to blank blue screen with internet icon, app icon, and settings icon. There is no place within settings to access maintenance or calibrate, and cannot access Main Menu. Any suggestions?
Lights up, start does not start on console, belt won't move , decline , incline does not work, age goes down but not up, speed does not work...pulse on handles work,,,
Do you have the iFit component on your treadmill? We had a similar issue and I unplugged the iFit component (requires opening the console and unplugging the ribbon cable that attaches the iFit component) and the treadmill started working again.
Jun 08, 2014 | Nordic Track NordicTrack Treadmill, A2550
I just got my Nordictrack X9i treadmill and assembled it. When I turn it on it will not boot up and says it has an update error. That's all I get nothing eles and nothing will work. Does anyone have any...
Have you connected the tablet to the internet via WiFi? As I am reading on your treadmill it has the ability to connect to internet and that maybe what it is looking for, so it can update itsself.
Jan 24, 2014 | Nordic Track Incline Trainer X9i...
I just bought a Nordic Track X9i incline trainer. Started working well, however after a few hours of use I cannot use any control keys and belt and incline does not work. The touch screen display works but...
You should immediately replace the console. That console will just keep getting worse. This is endemic of this brand, however it usually happens a lot further in the life of the unit. When you call Nordictrack have your model number.
Aug 11, 2013 | Nordic Track Incline Trainer X9i...
Nordic Track x9i screen stuck in boot
Disconnect wifi and boot machine. This works well for a non-internet workout. I had a similar problem--endless looping of the boot up routine--which ultimately fixed itself when I tried updating. I believe they came out with a new update which must have fixed some bug in the system.
Dec 16, 2012 | Nordic Track Incline Trainer X9i...
Ifit console will not load keeps running in a loop?
try to RUN the software calibration, see your instr. manual how to enter and proceed for easy diagnose, troubleshooting, and fix it.
God bless you
Dec 11, 2012 | Nordic Track Incline Trainer X9i...
Nordic track X9i controls not responding
Dear Sir:
Adjust the reed switch, see the diagram attached, clean, and tight the connector very well.
Anyway I recommend to call the service Help, in the place where you did buy your treadmill.
However you can RUn THE SOFTWARE calibratin for diagnose, troubleshootin, and fix it, follow the steps in your instructions manual.
sincerely. God bless you
May 07, 2012 | Nordic Track Incline Trainer X9i...
I have a Nordtrack viewpoint 3000, the tv will come on and when I touch the start botton it just beeps.
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. The first few times I would push the bad button until it started beeping. That worked for awhile (couple of weeks but started up again). I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
Aug 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
C2155 treadmill 1 1/2 yrs old, Nordic track. Panel lights up when the key is attached, beeps a triple beep sound fast about every 15 seconds? Keeps beeping when any of the buttons are pushed and won't...
Jun 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Reebok Flywheel For The Nordictrack Cxt 970 Elliptical Model Number Logo
52 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
