Question about Sewing Machines
Fabric wont feed and the lever doesnt change the feed. What can I do?
When I push the lever to raise the feed plate it doesn't move. What can I do.
    Problem Solver:
  • 4 Answers
Did you check the thread tension? And your bottom bobbin?
Posted on Dec 13, 2014
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
Why it wont the fabric does not move
There is a button or lever that controls the feed dog position. It might be dropped below the needle plate for darning. Locate this button and see if the feed dog are above the needle plate when you move the balance wheel.
Oct 12, 2014 | Sewing Machines
How do I fix the dogs when they won't feed the fabric?
The feed dogs on that machine (and many others) do not go back up when you move the feed dog drop button to up; they return to the up (feeding) position after the machine makes a stitch or two. So if they won't come back up after you tinkered with them, you will now need to bring it in for servicing.
May 14, 2014 | Brother XR7700
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
My fabric wasn't moving so I lowered the feed dogs and now I cannot raise them. The button in the back of the machine moves both ways but the feed dogs are not moving. They are staying in the down...
Hello
Turn off the power. Remove the accessory compartment located in front of the machine, if applicable.
Open the hook cover that shields the bobbin area. Please note that you do not need to remove the bobbin case.
Locate the drop feed lever near the bobbin case. Some machines have the lever towards the back of the free arm. Press down on the lever and then move it to the next notch or position. The raised metal feed dogs should be visible through the openings on the needle plate. You may need to rotate the big balance wheel one rotation to engage the mechanism on some machine models. The metal teeth will then spring up.
Close the hook cover. Insert the accessory compartment, if applicable.
Turn on the power. Try test stitching a piece of fabric. The raised feed dogs should help guide the fabric under the presser foot.
Jul 12, 2011 | Janome 4623 Mechanical Sewing Machine
Cloth does not move . It sews when I pull the cloth myself, but it does not automatically moves the cloth by itself
Make sure your feed dogs are up. Feed dogs are moving metal parts in the needle plate that make the fabric move forward under the presser foot. Open up the shuttle box underneath the needle plate. There is a lever to the right of the the shuttle. Press the lever down and to the left to raise the feed dogs.
Apr 03, 2010 | Kenmore 15358
I am still tryin to find a way to use the machine
When you cover the feed dogs, so you can move the fabric by hand (free hand embroidrey or quilting) you need to use a spring loaded foot that more than likely didn't come with your machine. You can pick them up at most sewing stores, maybe even you fabric store. Some are called a "free motion guide foot". They use a spring that raises and lowers the foot as the machie sews, so that you can freely move the material as the machine sews.
Oct 18, 2009 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Feed teeth have dropped down
Hi. Benieth the free arm there is a lever that you can switch from left to right. This raises and lowers the feeddogs for normal sewing and darning. Possibly you need to flip that switch lever. If that doesn't solve it then the freearm cover on the bottom needs to be removed and the feeddog mechanism cleaned and oiled. Could be stuck.
Good luck. Hope its the easy fix.
Rick
Jan 21, 2009 | Bernina Bernette 75
Kenore Sewing Machine Model # 158 Series
Remove the needle plate and clean the lint from the grooves in between the teeth. If there is none, while the plate is off ,move the lever and see if they will raise and lower. If they will not, you probably need to see a technician.
sewman7
Jun 16, 2008 | Kenmore 12102
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
