Question about Retail Supplies
I cannot use the beverage or food key on MA 1350. Alarm goes off and I only have the MA key.
Somehow, someone is in the (POOL) receipt area. Just drop the (L) and you will see what receipt I am talking about. I cannot change it. The alarm keeps going off when I hit the beverge or food key. My help was ringing up a sale and somehow hit the wrong keys. How do I clear the register?
Tech007
  • 63 Answers
SOURCE: Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Posted on Aug 29, 2007
SOURCE: How do I turn off Alarm only
On the left hand side of the phone (on the side) there are up and down buttons. Push the button up and it will change the ringer status
Posted on Apr 04, 2008
flexion1
  • 737 Answers
SOURCE: Royal alpha 601 sc cash register
Hmm. That is almost NEVER a paper problem, so forget about that.
It is always difficult to diagnose head problems without seeing the machine.
It can be a dirty thermal head, but that's not common unless something has been spilled on it. If you want to try cleaning the head, open the printer, and find the head. It is usually a small aluminium block that clamps against the paper when the printer is closed. it will always sit against the front of the paper. On that block, you will see tiny lines all very close together. They go to a connector at one end, and a thin black line at the top of the head. Wipe this black line firmly with a dry cotton bud.
Here is a picture of a thermal head:
http://www.jarltech.co.uk/ger_new/new/pix/products/web/printhead.jpg
Just above the light brown strip, you can just see the black line. This is what you would rub clean.
Otherwise, make sure the paper is clamping hard against the head while closed. If the clamp is not pressing with the same force at both ends of the head, then you will miss some printing. Try pressing against the back of the paper at the head while it prints, and see if it prints any more than before, then you know if your'e on the right track.
Hope this helps.
Mark.
Posted on Aug 18, 2008
Brian032472
  • 150 Answers
SOURCE: Cannot turn off security Alarm
If this is a factory alarm try using the the key in the door lock and turning the door lock manually. I have seen this issue in chrysler models as well. If this does not work try replacing the batteries in the key fob as this will cause falfunctions as well.
Posted on Nov 02, 2008
leecom72
  • 4806 Answers
SOURCE: turn my screen vertical again. i accedently hit the wrong button
CTRL+ALT+UP / DOWN / LEFT /RIGHT to rotate screen (only works on certain versions of vista)
Posted on Nov 18, 2008
I have a corsa sxi 56 plate , every time put key in ignition my car alarm goes off can any one help with this thanks .
Sadly this seems a job for an alarm specialist. Somehow your alarm system thinks your key is an intruder. Try an auto electrical specialist?
Aug 01, 2016 | Opel Corsa Cars & Trucks
Log in number tec ma-1350
I think this is the info that you asked about. Check it and see if this gets what you want. http://callcds.com/pdf/TEC/MA-1350%20Owners%20Manual.pdf
Oct 09, 2014 | Computers & Internet
Tec ma 1350
Look for the button written RCPT on/off and press it once
Jul 28, 2014 | Retail Supplies
Key won't come out of ignition, car won't start, panic alarm goes off when I try to start it
Sounds to me like you need a new ignition switch. Take the vehicle to a mechanic and have them further evaluate.
Jan 24, 2014 | Volkswagen Cars & Trucks
I have a tec ma 1350 cash register and slip price keeps popping up whats wrong
Had the same problem if the slip price light is on blow out the validation slot with a can of air its that simple
Dec 17, 2012 | Casio Parts Cash Register PC Desktop
Fridge not keeping temp. goes from 30 degrees up to 65 and back down again at random. losing food. help
I would investigate the thermostat first. It sounds like the most likely place to start based on the symtom
Sep 06, 2010 | Carrier Beverage-Air UR30GEFD Beverage...
Alarm only goes off if something goes off in deep end
These pool alarms are designed so any time something breaks the surface of the water, the alarm is sounded. They are designed for movement in the entire pool. Make sure that your alarm is positioned properly so that it is not strictly monitoring the deep end of your pool.
Jun 23, 2010 | Smartpool Pooleye Inground Pool Alarm...
EnV3 Ringer Volume TOO LOUD
There is a bug with this phone. All of them do this. The V05 firmware that came out 10-2-09 does not fix this. Sorry. I hate this too.
Oct 06, 2009 | LG enV3 VX9200 Cell Phone
Battery goes dead intermittently
Quite often the alarm system ends up being the culprit. If you have, or know someone, who has a clamp on amp gauge that can test the draw from that circuit, it should tell you what you need to know. It could be that or a combination of various draws from your system.
Mar 22, 2009 | 2004 Cadillac CTS
Car alarm
Not really a solution, sorry. But, my 93 celica had the same problems as your having now. Mine just worked when it wanted to. I had to end up having someone check it out. They basically said "Who the hell hooked up your alarm?" I have no clue, I figured it came like that, but I guess someone took it out and redid it. That may be your problem. Unhook your alarm or take it in and just ask someone.
Do you have a sound system? Most...as my previous owned did, like to somehow hook the sound system with the alarm. But of course when he sold me the car he took the system..leaving the alarm to go haywire.
Jul 31, 2008 | 1993 Toyota Celica
Retail Supplies Logo
60 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
