Question about Comet ZWD 4040 G-K Pressure Washer Pump With Built-In Unloader
What grade of oil do i use in the zwd 4040 hi pressure pump
    Scholar:
    New Friend:
  • 90 Answers
30 weight NON DETERGENT. Autozone and other autoparts stores usually have it. It is often hard to find, so you might have to ask them where they hid it.
Posted on Dec 16, 2014
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: I have a Pressure Washer
Derek, Hi and welcome to FixYa. I am Kelly.
I just now happened across your post and note it is 3 months old. Hopefully you already have the problem solved.
If not.. looking at the pump history of having the un-loader valve replaced it sure seems that the current un-loader valve is sticking. When an un-loader valve is removed the internal housing is sanded smooth and everything about the un-loader valve is coated with Lubriplate #105 White Grease. I get the feeling that who ever did the un-loader valve repair failed to sand / clean the housing and use White Grease for the final assembly.
You should remove the valve... Sand the housing and get some Lubriplate #105 white grease (auto parts store) in a tube. Lubricate it liberally and reassemble it. If should work fine after that.
Thanks for choosing FixYa,
Kelly
Posted on Dec 07, 2010
What causes the oil check light to show while there is enough oil
Low oil pressure.
Causes
1. Warn oil pump
2. Warn engine bearings
3. Wrong grade of engine oil
Could also be a bad oil pressure sender or electrical connector.
Remove oil pressure sender and and fit a manual gauge to check the true oil pressure.
Feb 27, 2015 | Cars & Trucks
Comet water oil
You have to take off the pump head. Here is the link to the service for comet pumps.
https://www.pwmall.com/PDF/CometServiceManual.pdf
Nov 03, 2013 | Comet GXD2527G Pressure Washer Pump
1999 JIMMY OIL PRESSURE drops with RPMs after warm
Normal is 10w30.
If the oil pressure gauge is correct, my guess would be worn engine bearings and / or oil pump.
Jul 14, 2012 | GMC Jimmy Cars & Trucks
I have a Coleman 2200 6hp green tochemsa engine pressure washer and wanted to know what type of oil is used in the water pump? PLEASE LET ME KNOW.
The recommended oil is determined by the pump manufacturer (usually different from the engine), but most of the "consumer grade" pressure washers say you never need to change the pump oil. Maybe they figure something else will break before it needs new pump oil?
The little jugs of pump oil at home improvement stores are usually SAE 30W (non-detergent) crankcase oil. 75W90 gear oil seems like a better choice; I personally use synthetic marine lower unit gear lube in my pressure washer pump. It's a little more expensive, but I think the formulation gives better moisture resistance. Besides, the pump takes a fairly small amount, and I don't change it very often at all.
Bottom line- you almost certainly want non-detergent oil, around 30W crankcase/80W gear (since they use different scales, these are just about the same viscosity). Synthetics seem to be higher quality, and using marine grade lube gives me peace of mind.
The pump oil matrix here is illustrative- note the many substitutions allowed. The specific oil you choose probably doesn't make much difference, especially compared to never changing it.
Jul 16, 2011 | Coleman Garden
I have water in the oil in the comet pump/ZWD 4030. It is on a North Star 3000 hpw.
You have a seal failure, you need to reseal the pump and change the oil in the pump.
Nov 04, 2010 | Northstar Garden
I have a Pressure Washer with a Comet ZWD 4040 Pump. It recently had a new Unloader Valve fitted. It has suddenly developed a problem, the pressure goes up to 3000psi and then drops back to 2000psi. I...
Kelly
Sep 15, 2010 | Comet GXD2527G Pressure Washer Pump
What grade of oil do you put in the pump not the engine
Pumps use a 30-weight non-detergent pump oil. Don't use motor oil.
Jun 20, 2010 | Porter Cable PCH3200 Commercial Pressure...
I have a Comet 4040 and oil and water mix is bubbling out of the red cap on top of my pressure washer. Can anyone tell me what repair kit I might need to fix this problem?
Hi this could be the oil and pump seals worn. Also make sure that you don,t have the transit plug in or the pump cannot breath. It should have a air vented dipstick.
May 21, 2010 | Comet GXD2527G Pressure Washer Pump
What kind of oil do I put in my Comet AXD2524G-T pump?
If the Comet Pressure Pump Oil is some kind of a
Synthetic Oil that supposed to be extra effecient than
an ordinary oil, then that will cost extra. If that is ordinary multi grade engine oil (SAE 20 - 40), then, you
can buy over the counter. Most synthetic oil have additive that give extra longer life to all moving parts.
Nov 27, 2009 | Plumbing
Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
Comet ZWD 4040 G-K Pressure Washer Pump With Built-In Unloader Logo
618 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
