Question about Admiral Washing Machines
My admiral washing machine is leaking from the bottom
Checked all of the connections. must be leaking from the bottom.
    New Friend:
  • 45 Answers
You are most likely going to have to lay it on its side and access the bottom where the basket drain is, their may be a crack or loose
Posted on Dec 13, 2014
Admiral washer leaks from bottom
likely if water in center of washer than drain pump , or hose
Oct 16, 2014 | Washing Machines
Admiral ATW4475XQ leaking from bottom but still washing fine
This could be a small hole in the drum or drain hose or valve for the water controls.
May 20, 2014 | Admiral ATW4475XQ
Admiral washer begins leaking water from the bottom during the spin cycle
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Jan 23, 2013 | Admiral AW22 Top Load Washer
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
My Admiral Washing Machine (5 years old) is leaking.
Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up,2 screws at the top inside will release the front panel for a better view.
Apr 11, 2009 | Admiral AW22 Top Load Washer
Water leaks under machine
Hi, * Inspect the water supply connections * Inspect the drain hose * Inspect the water pump * Inspect outer tub for cracks or corrosion * Inspect the tub seal * Inspect the tub bearing Pls rate my solution...
Mar 02, 2009 | Admiral AW22 Top Load Washer
Washer
Sounds like the top seals are worn, drum needs to be removed to replace top seals (2 off), job for skilled person.
Oct 24, 2008 | Admiral AW22 Top Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
one of 2 things, either the inlet valve is not shuting off or the pressure switch is not sensing the water level. both of witch would have to be repair by a qualified technician. this repair would be worth doing
Feb 17, 2008 | Admiral AAV7000A
Washing Machines Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
