Question about Sylvania 6432GG 32" TV
How to replace antena o a silvania TV 6432gg
The coaxial antenna terminal is broken
  • 45 Answers
Depending on your comfort level and soldering skills this is fairly straightforward pull the back off the TV identity the part, buy a replacement at radio shack swap it out
Posted on Dec 13, 2014
My LG TV is no getting signal on coaxial cable connector It works good with other components audio and video
what co-axial cable are you using on the antenna. Is it a video co-axial cable or is it a RF 50 ohm antenna cable ? They look similar but electrically they are different.
Aug 31, 2015 | LG Televison & Video
Why no coaxial fm connector on rx-884-v?
It's only no connector,like TV antenna socket. For coaxial antena cable, just plug it to 75 ohm and ground socket. No need jack/connector.
Aug 25, 2015 | JVC Rx-884v Theater Dolby Digital...
Good connection with tv, dvd ok, All cables properly connected but ..radio Tuner is not responding
You need to connect the radio antennae properly using the coaxial or the ribbon wire to the antenae so to get the best FM reception.
If this is not connected do so from the rear of the tuner/amplifier.
Feb 23, 2011 | LG LH-RH360SE Theater System
I have the Toshiba 62HM196. When the input is cable it appears to have no red tones however when the input is antenna there is red. is this the TV or the cable box?
It the cable box or the incomming broadcasting coaxial pay cable connection.U try a antena getting a free DTV air broadcasting signal ur got red wright?So it not the tv.
Oct 13, 2010 | Toshiba 62HM196 62" SD Television
It powers up but stay on a blue scrin ,Ican not change chanels . I am using a indoor antena pluged in
Use the "source" or "TV/Video" or "Input" button to change inputs.
Make sure you have the antenna connected to the correct input. (if there is more than one for coaxial cable.
Jun 12, 2010 | Vizio VX37L Television
Someone give me a tv antena can i make it a fm radio antena it has no wireing on it if i can how do i run the wire ?
there is bended rod called as dipole in ur antenna..both ends of dipole should be connected by a coaxial cable. connect it to ur fm recivers antenna. to have much gain cut both ends of directors which are strait pipes (2 to 3 cm)
Mar 10, 2010 | Televison & Video
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
I cant find the local antena connection on Philips 30 Inch UVSH TV
theres only one antenna connection on this type of set, you will use a coaxial connector and then depending what type of indoor/outdoor antenna,satellite,cable you opt to receive the signal from,then you must get into the tv sets "menu" and change the tuner to whatever it calls for
Sep 15, 2009 | Televison & Video
Coaxial output broken
If the connector end is not damaged and the tuner circuit board is not broken, you can solder this back onto tuner, and solder the end back on the circuit board. You should take the tuner out to do this proceedure. A TV shop usually charges $50.00 to do this.
Oct 24, 2008 | Sanyo DS20930 20" TV
Sanyo dvw 5000 setup
If you rabit ears have a ribbon cable you will need a coax adaptor. Radio Shack carries them. If you cant find them, you might have to get a set of rabit ears that has coax wires. The antenna will plug into the cable in of the DVR. You take the coax output and plug that into the tv using a coax wire.
Aug 04, 2008 | Sanyo DVW-5000 DVD Player/VCR
Sylvania 6432GG 32" TV Logo
47 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
