Question about Cameras
Hello. My canon eos 60d won't powered up. When i used it, it suddenly turn off. I thought the battery is empty so i charged the battery. When battery charged indicator shows full (green light is on without blink). When i inserted the battery the screen on the upper right side shows a blank battery indicator (battery picture empty and blink) even i not turn the camera on yet.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Unchargeable defective battery would do that. Sulfation in the battery. Replace battery. 10 to 20 bucks.
Posted on Dec 13, 2014
  • julita_m Dec 13, 2014
    I try the new battery and still have that problem..
MrsJGreen
  • 130 Answers
SOURCE: Canon Power Shot A710 is
The hand with parenthesis is your image stabilization. It sounds like if your images are turning out black, you may need service.
Try hitting your display button a few times and see if anything shows up on the screen.
Posted on May 30, 2008
Gryfox
  • 216 Answers
SOURCE: Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Posted on Nov 27, 2008
  • 14 Answers
SOURCE: Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Posted on Aug 21, 2009
  • 22 Answers
SOURCE: canon EOS 400D will not power up
Generally a fuse blows on these, on the DC/DC converter (psu ) board. This is situated on the front of the camera, fairly easy to get at just involves undoing loads of screws!! The fuse is marked "K", replace or short out with a thin piece of wire. May be caused by changing lenses with the power on, but not sure.
Watch for the charged flash capacitor though!!
Had this problem with mine.
Phil
Posted on Aug 02, 2010
amygooseanda
  • 5 Answers
SOURCE: Canon G9 blinking green indicator light
Go to this site and try emailing them: www.camerasandparts.com They just service the Canon Powershot cameras and they are wonderful for help with these. They do excellent work and are about half the price of Canon. Hope that helps, best of luck with the problem.
Posted on Dec 15, 2011
Canon 60d cannot turn on
when a camera won't power up, check a few things:
battery is charged. When the battery is in the charger, check if the charger acts like you are used to. The light should blink the same way and should go out, or start burning what the battery is charged.
Then check if the contacts on the battery and in the camera (battery holder) are clean and shiny. Eventually clean with a dry cloth or cotton swabs. Never use sharp tools. Then when the battery is in the camera again, listen and feel if the battery door locks correct.
The battery door or lid should engage a switch. That switch is there to stop all action, when the door is opened. Just to prevent memory damage, because the camera unexpectedly can lose power.
I hope it helps.
Jul 19, 2014 | Canon EOS 60D Digital Camera
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Unable turn on canon 60D i was reviewing the photo
Remove the battery and memory card, switch the power switch on for a few seconds and then switch it off. Make sure the battery is fully charged, re-insert the battery and try to switch on again without the memory card in.
Oct 24, 2013 | Canon EOS 60D Digital Camera
My 60d wont turn with normal battery but works fine with battery grip
Fuse is bad on one of your power broads in inside the camera, needs repair.
Oct 05, 2013 | Canon EOS 60D Digital Camera
The camera doenst start the ligth of empty battery is flashing the camera dont start
check for a blown fuse in the DC/DC board. Board is on top after you remove top cover, and the fuses are covered by a shield plate you have to unsolder. Fuses are very small and have letter codes like P or K
Mar 30, 2013 | Canon EOS 60D Digital Camera
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
An English copy of the Canon EOS 60D Manuel: I
You can download the manual and more from
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_60d#BrochuresAndManuals
Oct 11, 2010 | Canon EOS 60D Digital Camera with 18135mm...
Cameras Logo
105 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
