Question about Pride Jazzy 1103 Ultra Standard Power Chair
Have a Jazzy chair, went unused for unknown amount of time, and won't turn on when not plugged in. When plugged in, if you press the power button, the lights blink repeatedly after a tiny buzz
Not sure on the exact model of Jazzy chair, sorry. Just got it today. Plugged it in and it's been plugged in for a couple hours now, still flashing. Tried pushing the power button, checking the connection and the wall adapter, etc. does not turn on AT ALL when not plugged in. I'm disabled so can't check the battery connection inside the chair, but can have someone try that tomorrow.
  • 33 Answers
Could be connector oxidised, remove connectors and clean with rubber eraser and connect back. Battery could be almost flat.
Posted on Dec 13, 2014
Testimonial: "So I tried again, and the battery light flashes 10 times. I'm not really sure what to do about that - the manual says "excessive voltage has been applied to the control system - check the battery connections.""
  • 27 Answers
Your charger is a "smart" charger. It doesn't recognize a dead battery as something it can charge. What I usually do is get access to the batteries, disconnect them (keep track of where the cables go), and use a car charger to give a quick boost to the individual batteries, one at a time. Use the low current setting.
Then hook everything back up and use your regular charger.
Posted on Dec 24, 2014
Jazzy 600 powewr chair intermittion operation
The small click noise is the parking brake releasing to allow you to drive. the flashing is called a flash code that will give you an idea of what is wrong. count the amount of lights flashing this would indicate the problem. Post the amount of lights flashing and some could give you the meaning of the code.
Apr 28, 2016 | Pride Mobility Jazzy 600 Powered...
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
The chair won't go up even the slightest incline.
ask the provider to reprogram it with more torque
Dec 07, 2012 | Pride Jazzy Select 6 Indoor Power...
I have a Jazzy1113,it had been unused for several years.I did not take right steps to take care of batteries. I tryed several months ago to start and of course would not,but i do remember some movement...
There is a 7.5 Amp ATO automotive fuse on the rear electronics tray that is probably burnt out. The ammeter will not work when this happens. Also, if you have a bad on-board charger that will inhibit movement of the chair. Unplug the on-board charger and see if you get it to move. Hope this helps.
Jan 04, 2011 | Pride Jazzy 1113 ATS Indoor Power...
My dad has not used his Jazzy for about 8 months and it only comes on when plugged in and not when it is not plugged in. What can I try?
Most likely the batteries have gone solid while it was sitting unused. The gel in the batteries requires them to be put on a charger at least once a week even if the rider is not using the chair otherwise the batteries will go bad. Replace the batteries and that will most likely solve your problem. If his insurance bought the power chair for him, they may cover the cost of the replacement batteries. The batteries cost $75-$120 otherwise, and you will need two of them.
Aug 07, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113. The chair was doing great. The user passed away,
Naw the batteries are shot Get yourself two U1 batteries from a battery warehouse or store that sells batteries around $200.00 for two
Jul 23, 2010 | Pride Jazzy 1113 Power Chair
When i push the power key it beeps and two lights appear then it shuts off its been a while since ive charged it
Visit:Peeplo.com/Free+Repair+Manual & im almost sure as i have a disability scooter when its not in use use a decent trickle charger they can be left plugged in for up to 3 months,so your batteries are fully charged all the time & plug back in even if you do a 100 yards trip,lets be honest the batteries are not cheap,so get the most out of them.or if not in use for any period after they are fully charged disconnect them.
May 11, 2010 | Pride Jazzy 1113 ATS Indoor Power...
I have a Jazzy 1121,when I went to plug it in to recharge it, I noticed the lights weren't flashing like they suppose to and plus while it was plugged in I was still able to move the chair, when I...
The chair is not recognizing the charger. If it is an off board charger, check the pins in the conncector to be sure that one has not been pushed back. On board, check to see if the amp meter moves at all.
Oct 04, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
213 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
