Abnormal color on screen even after trying a replacement screen.
Tried replacing screen and factory reset but still get abnormal green and red coloring. Think now it is video card problem going to try to diagnose that as well but need more guidence as where the problem lies. I theorize it may be the ribbon that runs from the display to the board but haven't tried that, plus it's a pain in the rear to do. Will attach picture.
    New Friend:
  • 41 Answers
Do the external monitor work well? if yes is the cable from motherboard to screen; else is a gpu related problem. if the pc is being built in 2005-2007 years can be the "ros" problem (problem generated by the use of old soldiering machine with "ros" flux) no fix for that sorry.
Posted on Dec 15, 2014
Testimonial: "I believe that this was the problem sorry for the one year delay in replying"
How do I reset my Samsung account due to abnormal factory reset and processed failed
U have to connect ur phn to th wall charger let it charge for five mins thn let it be connected to th wall charger swtich it of completely thn hold power thn volume down key a new screen will come with Android logo navigation to tht screen is done through volume up/down key beadvised th data of th phn will lost completely secondly remove th memory card if u have any
Oct 12, 2016 | Samsung Cell Phones
Error ce40
Read this
http://www.copytechnet.com/forums/toshiba/78223-toshiba-estudio-281c-error-ce40-total-491000-a.html
and this
PRINTERCAT : Hi this is Michelle and i will be assisting you. PRINTERCAT : Error CE40:CE40] Image quality control test pattern abnormality(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color. PRINTERCAT : (2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" tocheck if the low-density pattern abnormality occurs for each color. The values under 320 for Y, Mand C, and under 220 for K are defined as low-density pattern abnormality. PRINTERCAT : (3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" tocheck if the high-density pattern abnormality occurs for each color and identify the color whichpattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality. PRINTERCAT : (4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "0" (Invalid). PRINTERCAT : (5) Perform "Enforced performing of image quality open-loop control (05-394)". PRINTERCAT : (6) Output the image quality control test pattern (04-270) more than one time and check the patch ofthe color identified in step (3) to see if the image is abnormal (Note). PRINTERCAT : (7) Replace the image quality sensor. PRINTERCAT : (8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Imagequality closed-loop control / Laser power (08-557)" to "1" (Valid). PRINTERCAT : (9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it iscompleted normally. (Error [CE40] does not appear.) Then perform "Automatic gamma adjustment"( Chapter 3.5.1 and 3.6.1).(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to576)". PRINTERCAT : Please note:Abnormal image:Blank print, Solid print, White banding, Color banding, White spots, Poor transfer, Uneven imagedensity, Faded image (low density), Uneven light distribution, Blotched image.''''''''''??320 or above (Y, M and C)220 or above (K)''??Under 320 (Y, M and C)Under 220 (K)Low-density pattern abnormalityCheck the transfer belt. If the cleaning is poor, correct thetransfer belt around its cleaning blade.'??To (9)''''''??Normal '??AbnormalCorrect the items related to the image.
Mar 24, 2016 | Office Equipment & Supplies
My Sony 32" TV with CCFL Back-light module started having green tint. On black colored images, green pixels are clearly visible.
according to your observation we called abnormal picture & common mode choke coils are defective l3000,whech are near to LVDS connecter there are 3 coils & must change all coils after replacing these coils your set will ok
Jul 10, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
I have a 51 inch Philips projection tv the red and green crosses are wavy in the middle at top and bottom of the screen
Depends on model number but if will not adjust in some area of screen the chips it uses are bad--not abnormal for the actual crosses to not be
perfectly straight but the colors aligned to them should not be visable.
Got some more info or a question?
Apr 28, 2012 | Philips Televison & Video
Kv32526 32" sony no picture everything else is ok can hear voices can change channels 1997
you should check the RGB, check the heater voltage from Fly back to the heater (CRT Tube), make sure there are about 5 VAC Voltage, if no damage is usually there at 1 ohm resistors, other than that the damage can be caused by any part of an abnormal color, RGB voltage not equal or one is weak or not functioning. in other words, the color Green or Red and Blue did not appear. consequently it will not appear on the screen image. the solution is to replace the CRT tube or CRT tube Recharge using special equipment recharging....
Sep 30, 2010 | Sony KV-27FS16 27" TV
Monitor color problems
First reset to factory defaults, if it's still abnormal see if the signal cable is seated correctly on both ends (monitor and video card) if that doesn't fix it try with another cable.
May 25, 2010 | Computers & Internet
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Abnormal picture
if it's an xr-32x (as it shows on this pic), it's a dlp projector, not an lcd. therefore no green filter. it has only a colorwheel and a dmd chip to affect the color. if it's not an xr-32x, and it's an lcd projector, replace the green filter. sharp sells the parts for the optical engine. but if it was your service tech that did it, have them replace it.
Jul 28, 2009 | Sharp XR-32X Projector
Computers & Internet Logo
David Payne
David Payne
