Question about Home
I have a push button flush on my toilet but the flush is getting less powerful and we have to wait ages before it will flush again despite the water level filling quickly????
Turning the water supply more oper to refill faster
    Dedicated:
    Visited the website for 20 consecutive days.
  • 341 Answers
Sounds like the syphon unit has scaled up. You can try flushing with a descaler fluid a couple of times to see if that will loosen the scale but otherwise replace the plastic syphon within the system. Cheap part, relatively easy fix if you know bit about plumbing. Confidence is the key.
Posted on Dec 13, 2014
How can I adjust the waterflow to a lower setting to make it 1.2 gallon flush from a 1989 3.5 gallon flush??
Keep in mind that if you limit the amount of water too much, the 3.5 gallon toilet will not flush properly.
This looks like an old Kohler Rialto toilet. The proper way to adjust the water level is to tighten down on the adjustment screw located on the very top of the fill valve. The fill valve is the the piece that the float ball screws into on the left side of the tank.
Tighten the screw down and flush the toilet. Wait for it to refill, and check the level. If you need less water, tighten again, let fill and check level.
There are also two old school methods to save water in your toilet. One is to put one or two bricks into your toilet tank. This reduces the amount of water that fills the tank. The second method is if the fill valve has a float ball on a metal rod, you can bend this rod down into the water. This makes the fill valve shut sooner. Don't bend too far or too fast because the chlorine in the water weakens the brass rod that the float ball attaches to.
Nov 29, 2016 | Home
Is there a way to change the toilet from front flush to top flush to accommodate the button on the top of the unit in the tank?
So did the top not come with the tank itself, is it a replacement? Or is it a tank where you can choose top or front flushing?
In my experience the mechanism for top flush is more complicated than front flush which just lifts the flapper. Take the top off and look. See if there is a link that can be taken from the front and clipped to the top. you state is has a 'self contained unit', so it doesn't sound like a standard lifting flapper, so you may well be able to choose.
Jan 01, 2016 | Home
Roca dual push button Toilet will only flush when holding the push button continuously down until the cistern is empty. It won't completely flush like it should when pressing the button once.
allow tank to fill a little more by adjusting fill valve. When there's not enough water flowing from tank the stopper can over-power the water flow and cause the flush to stop by re-sealing.
Feb 28, 2015 | Home
Flush for solids does not have enouvh power for a good flush
The problem probably is in your valve which regulates output of water. Normally on these types of toilets, this is and can be the common cause.
Apr 19, 2014 | Duravit 0910100005 Happy D Toilet Cistern ...
Uberhaus dual flush toilet power-assisted
buy a simpler toilet less problems and you will sleep at night
Jul 18, 2013 | Home
The lever (handle) to flush the toilet does not rise after it is pushed down, causing the toilet to run. One has to push the lever (handle)up after the down motion to make it function properly.
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the stopper valve preventing the toilet stopper valve from completely closing and causing the water to continually run. After re-attaching the chain I noticed when I flushed the toilet that the handle did not rise again until I manually pushed it up. After readjusting the chain to a tighter position where the chain was not floating at all but instead holding the stopper valve in place I again flushed to check the reaction. This fixed the issue of the water continually running and also the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
Nov 08, 2010 | Toto Home
I have a Carlyle water saver toilet. The one that has two push buttons built into the toilet tank lid. It is a solid 1 piece toilet. My problem is every hour the toilet is flushing by itself. Had a...
Hello. Your lid has two buttons so you can do a half flush or a full flush. A water saving feature. Since the toilet is flushing by itself every hour or so, you must have a leaking flush valve. Replace the valve to solve that problem. Joe
Oct 12, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
My one piece elongated bowl toilets are filling for no apparent reason between flushes what can I do to fix the problem
it sounds like your flapper (flush valve) is leaking.
if you here your toilet filling up and no one flushed.
push down on flapper to see if you here the water stop leaking out. if so replace flapper. even if toilet is 1yr or less old. could be a bad flapper. hope this helps. duane :)
Oct 11, 2009 | American Standard 2002.014 - Champion4...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
