Question about Air Tools & Compressors
5hp masport recycler starts but cuts out under load
Checked air filter,needs replacing
    Habit-Forming:
  • 79 Answers
Sounds like you have diagnosed this - what question do you have?
Posted on Dec 13, 2014
I cannot start my 635 masport mower
check to see if you have spark, fuel delivery and a clean air filter. If you have these then check your timing
Aug 31, 2014 | Garden
Masport morrison 470
I am guessing you are looking for the "Air Filter" Can be in 2 places, at carbie air box, or if a snorkel tube has been fitted the housing up at the throttle section will contain it.
If it has no snorkel it will be in the air box attached to the carbie, there should be a single nut/screw holding the cover closed.
Remove the nut/screw and the cover will hinge open and detach.
Dec 09, 2013 | Garden
Masport mower
take it back as the repairer has not completed the installation of the carby properly
and yes he is correct in that the user manual states in what position not to place the mower or the oil will get to the carby and air filter
Oct 11, 2017 | Garden
K750 cut off saw three new air filter,gas filter,spark plug saw loses power after 15 sec of hvy cutting
Piston rings are gaulded or stuck, easy to change and fairly inexpensive if you buy aftermarket parts on ebay. I believe piston, rings, and cylinder (if you need it) for less than $100.
Aug 25, 2011 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
I've been trying to start my briggs & straton Masport lawn mower, after it was sitting idel for over a year. Replaced oil ok / added new fuel / spark working, however it dies after fisrt kick...
You probably still have old fuel and water in the carb itself.
take off the air filter and look for the bowl screw or clip *(depending on model)
You can drain the bowl and let some clean fuel run through the gas line as well.
If the new fuel was last years you might want to check the gas can for water as well.
I work at a mower shop and at this time of year we do a lot of these kinds of repairs.
Fuel today just isnt kind to equipment that sits around for any length of time.
Mar 27, 2011 | Briggs & Stratton Briggs Stratton...
Saw runs great then bogs down 20 sec. after i start cutting i let off it runs good then bogs again when cutting after a few sec
Check your air filter, if clean chances are your carburetor needs to be rebuilt. the carburetor has thin diapragms that get hard and won't meter the fuel in fast enough.
Jan 30, 2010 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
5hp Briggs & Stratton lawnmower starts but stop running?
Try cleaning the air filter, and check fuel tank for any debris.
Replace fuel filter if there is, and give the fueltank a good cleanout.
Use fresh fuel to refill.
May 17, 2009 | Craftsman 16" High Garden Tractor Snow and...
Masport Lawnmower won't start
you likley will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder.
Mar 31, 2009 | Garden
Masport rota-hoe
try this forum, bruce there seems to be the man to know about ur machinery, he could more than likely help
http://www.outdoorking.com/forum/ubbthreads.php/ubb/showflat/Number/5827
Dec 08, 2007 | Computers & Internet
Air Tools & Compressors Logo
47 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
