Question about Optics
How do I order a slide bolt for 66 power master ?
T'v tried begging for it I want to buy one what do I do ??
Fix 2007 toyota sienna 2007 sliding door
Your question is too vague about the "problem". Is it alignment, latching, locking, handle, etc.? Try looking at the following links:
https://www.facebook.com/Toyota-Sienna-Faulty-Power-Sliding-Doors-233250320033754/
or http://www.siennachat.com/forum/66-problems-maintenance-repair/1300-sienna-power-sliding-door-problems-thread.html
hopefully you will find a solution there.
Mar 27, 2016 | 2007 Toyota Sienna XLE
How do I order a bolt for 66 power master
You can try :
Crosman Corporation
7629 Routes 5 & 20
Bloomfield, NY 14469
1-800-7AIRGUN (724-7486)
Open M-F, 8AM-4:30PM EST
Dec 12, 2014 | Optics
We have Rollei Projector P37E, where can we buy a slide tray for the same ?
Impossible to find new ones. They only fit this model and haven't been made in decades. Used camera specialists like KEH in Atlanta, GA might have some.
Jul 13, 2011 | Rollei 66 Dual Slide Projector
I have a 32 pt 66 3s37g philips tv It wont
No,U can try website like Remotes.com to buy the original remote,if u like.Take the tv aparts.The power supply board,that the board where the power a/c cord plug into it.That the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 11, 2010 | Philips 32PF9964 32 in. Television
How do i replace a power brake booster on a 97 ford taurus
  1. Step 1 Mark the brake lines coming into and out of the master cylinder using masking tape and permanent marker.
  2. Step 2 Orient the tube wrench so that it grabs the end of the nut by first sliding it over the brake line.
  3. Step 3 Pull the brake lines out of the master cylinder.
  4. Step 4 Unbolt the two bolts that hold the master cylinder to the brake booster.
  5. Step 5 Slide the master cylinder off the brake booster.
  6. Step 6 Remove the bolts that hold the brake booster to the firewall.
  7. Step 7 Remove the cotter pin from the pin holding the back of the brake pedal to the master cylinder.
  8. Step 8 Slide the brake booster to brake pedal pin out of the mounting bracket.
  9. Step 9 Pull the brake booster off the firewall.
  10. Step 10 Install the new brake booster. Installation is the reverse of removal.
Apr 24, 2010 | 1997 Ford Taurus
The crank to raise and lower the blade on my powermatic 66 is really hard to turn, any suggestions?
The square tooth screw and nut tend to fill with sawdust, which saturates with oil to cause the threads to bind (like a dirty nut and bolt.).
Clean the bolt with a cleaner, then apply a little wax to the threads (crayon or bees wax). Be sure to run the assembly up and down to cover the whole "bolt" and make sure to apply to the point of the screw that assures some of the wax works into the nut.
Wax is less likely to cause wood dust "mud" that WD-40 or other lubricants would cause.
Check the slides or guides that guide the assembly as well. CLean and lubricate with wax as needed.
Let me know what you find out.
Dec 12, 2009 | Powermatic 1660804K 66 10" 5 HP 3 Phase...
How do you get a power booster off a 1999 town and country van?
Your power brake booster is bolted to the rear engine compartment, or firewall, from the inside , so you need to disconnect the rod from the brake pedal, and locate and remove the bolts that hold it. You also have to unbolt your brake master cylinder too.
Nov 16, 2009 | 1999 Chrysler Town & Country
Rollei 66 Dul P projector
I've only worked on one or two of those, with no training in that brand. Good machines but I suggest you try an authorised service shop. here are some links to try
http://www.sl66.com/pg/repair.shtml
In Canada, this company *might* be able to help you. Kominek
405 Yonge St
Toronto ON, M5B 1S9
Phone: 416-977-2132
Mar 14, 2008 | Rollei 66 Dual Slide Projector
Optics Logo
169 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
