Question about Sewing Machines
Turning on the power makes the machine run FAST....how can I get it to stop?
Everything I could find...
  • Sewing Machines Master
  • 1,860 Answers
If you turn the machine on and it's running by itself then the machine may have a short in the wiring,, or there could be something wrong with the motor
Posted on Dec 19, 2014
Sewing Speed slowed down then stopped. The motor seems to have the power it needs but will not turn the gears fast enough to sew. Any thoughts what might be the cause?
You didn't state the make/model of your machine. If it is a mechanical sewing machine, it probably could use a good cleaning and oiling. If the old oil has solidified, it is sticking the parts together and preventing them from moving. Do NOT force the motor to try to run the machine until you get a resolution to the issue or it could burn out the motor.
Apr 18, 2016 | Sewing Machines
My mom's old singer will start sewing then slows down to a stop.
It may need a REALLY thorough cleaning & oiling, Cindy, including the motor bearings. The motor's windings may be getting weak, too, or the new belt may be slipping.
Aug 11, 2014 | Singer Sewing Machines
Why My se 400 sens I bought it it's running very slow
look for the speed control knob. turning that should make it sew faster. usually it is quite big.
Jun 06, 2014 | Brother Sewing Machines
Singer motor hums
You don't say whether your machine is newer or an antique. The model number would really help your helpers help you.
Let's work on your vocabulary a bit: A presser foot, is what holds the material down so the feed dogs and move it through the machine. The foot pedal is pressed to make the machine go. ;)
However this sounds like a machine that needs service... by your explanation of how you change the speed to fast and run it fast... it sounds like one of the modern electronic machines. Since modern machines don't have oiling and greasing guidelines I suspect your machine I well overdue for servicing. Find your local sewing machine tech and take it in. Ask for a "Clean, Oil and adjust timing" and be sure to mention the motor issue. While he's there ask him to check the belts and replace if necessary.
Good luck.
Feb 26, 2013 | Sewing Machines
My viking 990 foot control when pressed runs intermittenly, fast stop slow fast. help
the foot control needs to be checked because it shouldn't be doing that
May 16, 2012 | Husqvarna Sewing Machines
There's not enough power to make the needle move up n down fast enough?
if you have check the power cord & foot pedal to make sure they are plugged in the machine correctly
then I suggest taking the machine to a sewing machine repair shop to be
checked
Apr 30, 2012 | Sewing Machines
My machine's screen keeps turning off but the function buttons stay lit. The machine appears to reset itself randomly while im sewing and sometimes even when im not near it. Everything else seems to be...
Has your Designer 1 ever had the power supply replaced? Almost all Des 1's had a recall that was replacement of the power supply. Any Husqvarna Viking dealer will be able to check the power supply, or transformer, in your machine and make sure that it has been replaced. Sometimes this can be a loose connection inside the power supply.
Sep 17, 2011 | Husqvarna Designer I
FOR HOW LONG AT A TIME CAN I RUN MY EURO PRO FAST AND EASY 420 MACHINE WITHOUT IT OVERHEATING?
Domestic machines are not made to run at contsant high speed for long periods of time, the chances are the machine will give before the motor and then the strain of the mahine will burn the motor out, they are made purely for domestic use, stop and start, a lot of people use them for doing outdoor work much to their cost
Aug 31, 2011 | Euro-Pro Fast and Easy 420 Mechanical...
My machine continues to run after i take my foot off the pedal.
Undo the foot control and take out the little square bit called a suppressor which you don't need these days anyway and it should be fine.
Jan 19, 2010 | Singer CE-200 Quantum Futura Computerized...
Motor is sluggish, Necchi Model#4795
Set machine to wind the bobbin to check for how fast the machine will run. I believe it will run fast or slow according to how hard you depress the foot control. If it runs fast and slow you have a problem in the machine. Most likely the machine, if turned by hand, is hard to turn and it needs to be professionally serviced. before it is ruined.
sewman7
Dec 29, 2008 | Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
