Question about Brother Se400 Computerized Embroidery & Sewing Machine
Thread is not staying in the needle bar thread guide. It is slipping loose.
I've tried re-threading the machine, cleaning the machine, changing the needle ... none of those things will help, but just in case.
    New Friend:
  • 28 Answers
Hi try to make sure the thread is in between the tension wheel as you thread and sometimes turning the spool over works hope this has been of some help
Posted on Dec 13, 2014
How do I thread hobby grand quilter 1200
The Hobby 1200 is a Pfaff sewing machine that they call the Grand Quilter. First raise the presser foot and make sure that the needle is at the highest position (press the needle up/down button twice with the machine on). Then turn off the machine and unplug it for the maximum safety. For the top thread, place a spool on the spool pin and guide the thread through one of the two thread guides on the thread guide bar. The thread starts from behind the guide. (The post holding the guide bar is next to the spool pin.) As with most sewing machines, you will work from right to left and lead the thread down then up before going down to the needle. Bring the thread to the next thread guide (in front of the bobbin winding pin) and pass it through one of the holes from the back. Wrap the thread to the back of the guide and then through another of the holes. If the thread tension is very loose, try going through all three holes. Bring the thread down between the pre-tension discs going counter-clockwise.
Hold the thread in both hands and guide it around down and around the tension dial from right to left. Bring the thread up to get it between the tension discs and behind the tail of the check spring. Bring the thread back down over the loop of the check spring then under the thread guide that looks like an upside down L with a curve in it. Bring the thread up and through the next thread guide. (This guide is horizontal and just above the previous guide and one side ends near the center of the tension dial.)
Bring the thread up and pass it through the eye in the thread take-up lever and then back down through the horizontal thread guide above. Slip the thread into the thread guide and then down to the needle bar thread guide. Thread the needle from front to back. The thread should be along the groove in the needle.
You can find the manual at Pfaff's Machine Update page: http://www.pfaff.com/en-US/Support-and-Updates/Support . Search for the model and then you'll get to the product page: http://www.pfaff.com/en-US/Support/3336 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/GrandQuilter-manual-EN.pdf . The threading section starts on page 21 (page 23 of the PDF). The manual has good pictures that are better than my attempts to describe the guides.
I hope this helps.
Apr 28, 2018 | Sewing Machines
Thread the needles
cheap thread will break easily. Make sure you buy good quality thread. If you want to test to see if this is what your problem is, buy four small spools of Coats and Clark thread, I even use it for embroidering. It doesn't break easily. If it doesn't break, it is your thread. If it breaks, your tension is too tight on your machine.
Oct 16, 2017 | Sewing Machines
I can't figure out what the thread guide is on my singer machine to thread the thread through to the needle?
The biggest problem most people face when having troubles pull the bobbin thread up is one of the following.
Wrong needle size (or broken/bent or otherwise damaged needle)
Needle is not fully set into the needle bar.
Needle is not correctly oriented.
Pulling up the bobbin thread is a simple matter of threading the upper thread, and inserting the bobbin with about 6 inches hanging loose. Grasp the top thread lightly.... turn the wheel counter clockwise one full revolution (the needle will go down and back up.) Just pull the top thread slightly and you should see the loop come through the throat plate. Use something like your scissor point to swipe under the presser foot to help retrieve the bobbin thread.
What is the model of your machine?
Aug 28, 2012 | Singer Sewing Machines
Top thread breaking?
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Apr 22, 2012 | Sewing Machines
My thread keeps breaking at the end of my sewing session. not sure why, I've been sewing blocks for a quilt and I've tried to change the thread
Upper thread breaks
1.needle may be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
2.upper tension may be to tight--try 3 to 5
3.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
4.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 12, 2011 | Sewing Machines
I've had this machine for over 10 yrs. The problem is that I cannot seem to get the tension adjusted correctly. I was sewing through a batch of triangles and all of the sudden the thread under the...
try these suggestions,see if they will help
try changing thread--top & bobbin,, some thread does not stay good as some other does
usually needle have a flat side goes to the back of the machine, make sure the needle is pushed up into the needle holder--is it the right needle for the fabric
and even if it's a new needle, I'd try another new one,,it's possible it could be bent or blunt or warped
check the thread take up lever to see if the top thread is still on it, when the thread comes off the take up lever it can jam up a sewing machine
check the needle plate to see if there are any burrs on it
also clean under the needle plate & bobbin area for loose threads or lint
Sep 05, 2011 | Bernina Virtuosa 150
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
Janome jd 1822 when i'm doing zig zag, the thread is missing stitches and also my threads keep breaking
rethread the machine getting every thread guide
check the thread tension 3 or 4 is usually good
Change needle--make sure the flat side is toward the back of the machine & that it's insert as high as it will go--make sure the needle bar is raised to it's highest position
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin that the bobbin is wound correctly & put into the bobbin case or shuttle correctly
here a tip about needle & thread compatability
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 24, 2010 | Janome Sewing Machines
Loose thread on bottom of fabric and locks up needle
Change needle
& bobbin
Check tension 3 or 4 is usually good
Nov 23, 2010 | Toyota STF17 Sewing Machine
The machine is eating my material
try changing thread top & bobbin
make sure the bobbin area is clean of lint & loose thread
make sure there is no lint in the feed dog area
change the needle
make sure the thread stay on the thread take up lever
sometimes needle & thread are not compatable-try this
if none of these suggestions work then the machine may be out of time & needs to be repaired
Nov 02, 2010 | Kenmore Sewing Machines
Brother Se400 Computerized Embroidery & Sewing Machine Logo
66 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
