Question about Boating
Boat engine Mariner 55el 663L 322230 What year please ?
Proper Maintance program for 1986 mariner 150 hp 2 stroke boat motor
The biggie is changing the lower unit oil,, making sure its not getting water inside,, R&R the fuel filter, R&R spark plugs, grease all fittings.. DOUBLE check the steering cables... they rust and corrode from the inside...NOT fun to be in a boat when the steering cable breaks!!!!!
Mariner Outboard Service Repair Manuals by Seloc 1977 2004
Jul 08, 2017 | HP Boating
What year and model is mariner 75 serial number 9502368
Hey Arthur,
This serial number does not show up..???Please look for more numbers on any plate or freeze plug..
These guys can help.. need more info though...
Outboard Motors Boat Parts Marine Engines Inboard Boat Motor
Jun 20, 2017 | Boating
Hi, have a mariner 75hp outboard serial number 9502368. Can you please identify year and model so I can order spares
Hey Arthur,
These guys will take care of you,,, that serial number doesn't satisfy the rewquirements for a search...? They will need more info.. more numbers on any plate..freeze plug..look around the outside of the engine carefully..
Jun 19, 2017 | Boating
6fos 000292
only numbers matching yrs are a 60hp mariner 1983.
Jul 20, 2014 | Light Outboard Motor Boat Bass Fishing...
Gday,i have picked up a 14ft boat with a Mariner outboard 60HP 2cyl but theres no compiance tag or numbers to show exactly how old it is,the wireing is there but nothing is connected to starter switch...
Mariner Trigger Assemblies
60 3 1984-1990 6428681-D000749 68162A 3, 68162A 3, 68162A 6, 96455A 1, 96455A 8 134-6453 18-5797 60 3 1991-1997 D000750-OG589999 99021A 3, 99021A 5, 99021A 8, 99021A13, 99021A15, 99021A16 134-9021-3 out of stock - 65 3 1976-1979 4382057-4571651 68162A 3, 68162A 3, 68162A 6, 96455A 1, 96455A 8 134-6453 18-5797iboats.com
You can look at your parts and determine your serial number and year.
Direct link to the page
http://www.iboats.com/Mariner-Outboard-Electrical-Parts/dm/cart_id.556536444--session_id.729929016--view_id.268684
Mar 22, 2010 | Intex Mariner 400 4 Persons Boat Raft Set
Is it compatible 3.5 HP engine with the boat? (mariner 4) if yes , when i used %30 of power just alone back side go down and can not control properly . engine is TOHATSU M 3.5 S
Your motor is too large.
For the Intex Mariner 4 Intex recommend an absolute maximum of 3HP (2,2kW) and the motor must not weigh more than 40lb (18,2kg).
Those limits assume that you are using the Intex motor mount kit (Part No. 10658) and that the boat is correctly loaded and inflated.
In reality and from experience I would personally recommend 2HP maximum power and to keep the motor as lightweight as possible. Although the Intex Mariner 4 can take a motor mount, it's really a rowboat and is not suited to using a motor for extended periods, but just as a convenient tender to a larger boat it's fine.
Dec 15, 2009 | Intex Mariner 4 Boat Set
Can Intex mariner 4 carrie an engine Yamaha 8 HP with a modificated mount if the engine have 60 pounds?
no. my 28 lb 3.5 tohatsu strains the pvc material that the tubes are made out of pretty well. the weight and thrust of the motor pulls pretty hard on these tiny little rubber "feet" glued to the tubes. I usually dont even run full throttle as it looks like i will pull the motor mount feet right off the tube. I couldn't imagine a bigger, heavier motor than what i am running working out well in the long run.
i have the intex mariner 4, btw.
Oct 15, 2009 | Intex Mariner 4 Boat Set
My serial # is 682c 356544 for my mariner 9.9ml trying to find the year?
Have you googled your Model number . Try to put in 9.9 Mariner boat motor plus model number . You should be able to retrieve it . If that does not work let me know Ed.
Jun 18, 2009 | Boating
Boating Logo
78 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
