Question about NAD Audio Players & Recorders
My NAD T747 keeps shutting down in Protection Mode at 6db when it used to go much louder. I cleaned the unit. Still nothing.
I played with the speaker settings and distances but no avail. Not sure what's next.
  • 74 Answers
Modern AV receivers such as your NAD have protection circuits to prevent damage when there is a short on the speaker terminals. Look carefully at the speaker connections on the back of the AV receiver- for example, the speaker cable for front left speakers labelled + and - : there should not be any stray strands of wire that connect from + to - ; this would be a short circuit. Check each of the connections on the AV receiver as well as on the back of each of your Speakers themselves. Also ensure all connections are snug (do not use pliers). If this does not solve your problem, you may need to take your AV receiver on for a service checkup. Good luck !
Posted on Dec 13, 2014
Hi! I have purchased a JAMO S608 HCS 3 and a SUB 650 using an OKYO TX-SR508 Receiver. I can't set it up correctly. When I played music I've heard a lot of bass, I think there are some high...
The TX has speaker setup and test tones for setting the balance and distance with test tones and proving the hardware works. If that all works the difference is probably external or settings.
What is different between the music source(s) audio and the HD movie source(s) audio? Ask yourself, how would a sub make high frequencies go missing? It can't.
Your other speakers are responsible for conveying the high frequencies.
Sep 08, 2011 | Jamo SUB-650 Subwoofer
Only subwoofer works at high volumes
It could be your receiver but you can try seeing if the Woofer has a input knob at the back, maybe this down, or maybe.if possible turn down the amount going to the woofer with your receiver.
Dec 27, 2007 | Kicker 02S10L74 Car Subwoofer
When i play music, the sound would come out from one speaker only. the audio jack seems to be fine, but do not know what is wrong. my model in logitec LS21
Hello
Try going to control panel,audio,settings.Make sure your speakers are set to 5.1 surround sound.
Next if there is software for these speakers or your audio device be sure it is also set for surround sound.
Apr 25, 2011 | Logitech LS-21 2.1 Speakers
Sony STR 1200 audio-visual sync
Yes it can be fixed.
Enter the speaker setup menu and toggle till you get to the selection for speaker distance. Assuming that you have your speakers properly positioned for correct reproduction of 5.1 surround sound, decreasing the setting for speaker distance will help. Start with 3-4 feet closer from the current setting. This enables the on board DSP (digital signal processor) to delay in milliseconds, the sound output for closer distance settings. It can also advance in milliseconds as well for further distance settings FYI.
Mar 24, 2010 | Sony STR-DA1000ES Receiver
Ba745 user manual
I'm sure that there is some special software available, but its unnecessary. You can just plug them in and have a listen. Sorry, I'm not sure where to find a manual.
Mar 19, 2010 | Boston Acoustics BA745 Computer Speakers
No Sound Whatsoever, Either From Speakers or Woofer
Disconnect the cable from the laptop and try to get sound out from the laptop via speakers or headphones, have a look around the sound settings.
Mar 22, 2009 | Audio Players & Recorders
Yamaha HTR-5840 best eq setting to start or use as base line
there are many settings 1.distance (This is the distance between you and the speakers) if your sitting say 6 ft away then you set it to 6 and so on (all front speakers should be lined up the same distance from you) The rear speakers are set up the same way (distance from where you are sitting) then 2. small and large (always pick large for best sounf)3.Tone (this is more a matter of choice) play around a bit with it! the sub should be at least one foot from the wall for best sound! I keep my center chanek a little lower then the other channels for best sound !
Dec 18, 2008 | Yamaha HTR-5840 Receiver
One speaker is lower volume than others - right front
I think that maybe you setted the distance of the speakers wrong. Check your users manual and try to adjust the distance.
Nov 17, 2007 | Sony STR-DE597 Receiver
Echo when playing surround sound
You want to adjust the "DELAY" setting on the receiver. The standard (default) delay setting is 20mS, which may need to be shortened if your speakers are well behind your listening position. In a proper setup, you should not detect a significant echo effect in surround programming (unless it is a purposely "echoey" scene). Also, make sure you don't have any of the "enhanced" DSP modes engaged -- some of these are quite echoey. if it has speaker set up, there should be a setting for distance. You might have it set close, so that by the time you hear the fronts, the rears should go. Try setting it farther each time until it sounds right. good luck
Mar 24, 2006 | Teac AG-D8900 Receiver
277 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
