Question about Maytag MTB1956G Top Freezer Refrigerator
Change light bulb in Maytag MTB1956GE Refrigerator. Cannot loosen bulb. Cannot remove plastic "cage" around bulb.
Tried to loosen bulb. Tried to remove cover "cage" nothing nudges.
  • 1891 Answers
SOURCE: Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Posted on Dec 03, 2009
Testimonial: "Thank you! Got it fixed!"
heatman101
  • 43501 Answers
SOURCE: Water is dripping from the
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 25, 2010
allbrands
  • 600 Answers
SOURCE: How do I remover the
Hello, Thank You for using FixYa. I will be helping you today. The vent or grille part just pops out and behind it are two screws remove the two screws now you can remove the cover. The damper is just held on by a clip an each side. Here is the part Control, Damper Part #: 67003903
Thank You and please rate my answer if it was helpful..
Posted on Jun 21, 2011
  • 2006 Answers
SOURCE: do I clean under maytag
The condenser coil is located under your refrigeraotor and it does take a special brush to clean them good.
http://www.fullerdirect.com/products_detail.asp?cat=1&subcat=5&id=216
Posted on Jul 05, 2011
  • 884 Answers
SOURCE: Light not working in Maytag Plus 134A Refrigerator
Sure you've got power to the bulbholder? Check the switch
Posted on Sep 07, 2012
Change light bulb in Maytag MAN1956GE Refrigerator. Can't loosen bulb. Can't remove plastic "cage" around bulb.
Hello Jane;
My name is Peter. I am a retired field service refrigeration technician.
What you have provided is the standard manual number not the model number. The model number is on a label on the inside wall of your fresh food section near the top.
You may have a single screw holding the light cover on.
Note; the bulbs in a refrigerator like all of you appliances is specially designed for the service. They are a little expensive $8.00 - $10.00 each. Some food markets carry them. If not Lowe's or Home Depot.
Go into the following link put in your model number and a diagram will appear to help you.
Water Filters Lawn Garden Appliance Parts
Dec 12, 2014 | Maytag Refrigerators
I cannot remove light bulb Maytag model mtb2156de refrigerator
Unplug unit heat plastic light socket with blow dryer and use leather gloves. If the glass breaks bend in the broken light bulb socket with needle nose pliers and turn out.
Oct 30, 2013 | Maytag Refrigerators
How to replace the light bulb in the Maytag french door bottom freezer
Hopefully you have figured this out. Its fairly simple to do. If your freezer if full you will need to empty enough that you can place your hand in and on the Plastic Light cover. Its in the center at the top of the freezer. This cover is removed by simply applying a little pressure to the right and left corner and pulling toward you and down. The light cover with very little pressure should mover and pull down. Once it begins to lower in the back just keep a hold of it and mover your hand toward the rear of the freezer and the front tabs will slide out.
After changing the light bulb, simply put the front two tabs of the front of the cover in first and snap back into place by pushing up. Takes about 3 minutes to change the light bulb. Good Luck!
Dec 24, 2012 | Maytag MFD2560HES Bottom Freezer French...
How do I change headlight bulb on 95 cutless
This is actually quite simple. If you open the hood and look behind the area of the headlight, you will see a brown or gray plastic ring with 2 or 3 colored wires passing through the center. Remove the wires as a group with the connector. Then turn the plastic ring counterclockwise to remove it.There "may" be a small light wire cage over the bulb to prevent it's falling out. Just swing it to the side and remove the bulb. The replacement bulb has to go in with the flat side of the connector facing up. Replace the cage, if supplied, and the ring. You're done. Check the lights for operation. Thanks, Dana.
Mar 31, 2012 | 1995 Oldsmobile Cutlass Supreme
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
How to change bulb in fridge
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Jul 04, 2011 | Whirlpool Refrigerators
HOW TO CHANGE THE LIGHT BULB IN THE REFRIGERTOR
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb you can buy a new bulb at any home improvement centre. Insert the new light bulb and replace the cover.
If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair centre that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Check this link if it helps:-
http://www.ehow.com/how_4856659_change-light-bulb-whirlpool-refrigerator.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Oct 01, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
Water is dripping from the vent at the top of the refrigerator. The refrigerator is a Maytag top mount, model no. MTB1956GE.
heatman101
Sep 25, 2010 | Maytag Refrigerators
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Jan 01, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Maytag MTB1956G Top Freezer Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
