Question about Sport & Outdoor - Others
Dept 56 rockerfella skating rink, tree won't light
3 Suggested Answers
MOTORWIZJ
  • 1358 Answers
SOURCE: How to repair the motor in a Dept. 56 Village Animated Skating Pond?
first check the plug 4 a fuse LOOK CLOSE ! next with a volt meter start by checking the switch for power, you will need to go deeper into the unit to find out what 4 sure failed.. I would make the nephew fix it he broke it .. you can let him watch but you might be working with 115 volts and safety must be taken ! .. hope you get it giong .. jay the pump guy in longwood fl
Posted on Jan 28, 2012
Testimonial: "Thanks so much! We finally evaluated the plug and found the cord/plug WAS faulty as you suggested. Simply replaced the cord and power restored. Have some other issues in getting it to run smoothly but will ask separately. Thank you very much again for suggesting a first look at the plug!!"
jerry_kramer
  • 3904 Answers
SOURCE: How do I make my dept. 56 trees stop blinking? Just stay on steady?
These are usually controlled by a flashing bulb. If you only have one bulb then change it out for a bulb that is normal. If there are multiple bulbs then look for the one that has a special marking or colored tip to it.
Posted on Jan 19, 2015
My daughter broke the part of her skates that holds the break can I replace this and if so from where and how
try phoning your local roller skating rink they may have a service to fix skates or will be able to advise where there roller derby skaters get their skates repaired locally.
Aug 23, 2015 | Cycling
The skaters won't move on my Dept. 56 Village Animated Skating Pond. The motor is running but I'm wondering if the problem is the magnets on the bottom of the skaters. Any ideas?
Try taking off the yellow disks on the bottom of the players. Also, take the skating rink off and examine if the belt is turning the main gear around. It could be slipping.
If you do that, would you kindly examine the magnet which runs the player around the rink. I am at a loss as to what keeps the tension of that magnet against the pattern which is on top of the main gear. A picture would be great. If so, please send to billwodrich@gmain.com Thanks
Nov 30, 2014 | Dept 56 Department 56 Snow Village "Hockey...
When I fill my ice rink, should I use hot or cold water?
Cold water is best for building up depth. Hot water makes for a stronger, smoother surface after a base depth is established. At least one hot water flood is recommended before skating for the first time.
Feb 03, 2013 | Skating
When I fill my ice rink should I use hot or cold water?
Jan 17, 2013 | Sport & Outdoor - Others
I have a Backyard Ice Rink. my question is will the blades on my ice skates cut the rubber lining on my rink?
No because they feature a Liner protection system that uses flexible ribbed PVC caps that snap over the frame, protecting the Liner from shovel & skate cuts. If you do get any small cuts in the liner you can use duct tape to cover them.
How Thick Does The Ice In The Rink Need To Be?
You must have a minimum of 2'' (two inches) in order for the ice to hold the weight of a 300lb person & remain solid.
Jan 05, 2012 | Toys
My skates turn on their own so how do you fix it
try turning the wheels around so that the outside is now the inside
Sep 29, 2009 | Chicago Skates Women's Chicago Deluxe...
Sport & Outdoor - Others Logo
508 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
