Question about Taylor & Digital Scale Lithium Scale
Reset digital scales model constant 14192-25
Power ok but does not give any weight reading need to re set place 2p coin on scale plate flashes numbers randomly then returns to 0000
ButtFuzz
  • 463 Answers
SOURCE: My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
Posted on Mar 16, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
abrahamangel
  • 5 Answers
SOURCE: Can I adjust the weight on the scales to match my
Adjusting the scale is not a solution but adjusting your weight all in 60 days.
No strees, side effect or bitter drinks but all natural flavour beverages. Tested & trusted ISO 22000-2005.
YES U CAN, ITS BETTER TO BE ON THE SAME PAGE WITH YOUR DOCTOR.
Posted on Oct 14, 2009
F1xer
  • 415 Answers
SOURCE: Taylor Model 7314 Lithium Scale: Scale
Try stepping off the scale when you get an error message wait 5-10 secs then step back on, remember to stand still when the scale is giving a reading
Posted on Aug 15, 2010
What does it mean when my us-magnum 1000xr pocket scale says rCAL and keeps flashing 500.0
You need to send it out to the manufacture and have it recalibrated. Hence the code RCAL.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Feb 24, 2017 | Pocket Health & Beauty
Model WW710. Why is operation erratic?
Only thing you can do for the erratic operatic is check the condition f the battery, If that is not it then the scale is fubar.
Sep 25, 2015 | Conair Weight Watchers Glass Digital Body...
How do I reset my ozeri digital scales that read body fat percentage
I fixed this on my scale by going through every profile and changing the height and age, setting the two main ones correctly (but swapping my wife and mine) and then setting the rest to be very short and young. Then I pressed Set, picked my profile again, and weight myself. At this point I no longer got the PIP2 error.
Jul 31, 2014 | Ozeri Precision II Digital Bath Scale...
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Taylor & Digital Scale Lithium Scale  Logo
290 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
