Question about Bosch Washing Machines
Bosch front loader wag machine. Been unplugged for 6 months now shows no power. Have cheched powere supply this is ok help
Been unplugged for 6 months. Now no power showing on panel. Have checked power supply using another appliance supply good
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 136 Answers
Check for rodent damage to internal wiring
otherwise main control has failed
Posted on Jul 26, 2015
IFIXALL
  • 868 Answers
SOURCE: No power to my WF 860P front loader washing machine
You have a bad control board,it is the first thing to replace.Whats probably causing it to fail is the off balance tub sensors.
Posted on May 24, 2008
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
SOURCE: i have a bosch classixx 6 1400 express washing
Hold the start button in for 3-5 seconds and it should release it.
Posted on Feb 21, 2010
  • 174 Answers
SOURCE: ERROR CODE E50 SHOWING AFTER POWER SUPPLY INTERUPTION
It was probably your washer that tripped the electric . e50 relates to the motor check the carbon brushes they will be worn out. hopefully with new brushes you will be back in action. the programme wont start with a fault on the motor
Posted on Jul 24, 2010
  • 500 Answers
SOURCE: Bosch exxcell 7 washing machine
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Posted on Jul 08, 2011
How do I fix my Bosch Maxx 6 washing machine. The drum wont rotate? Can I reset it?
Check the drum motor power supply if its OK then problem can be in the control box try to figure out the trouble. And trouble shoot it
Jul 19, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
How do I clean the mould in the rubber door seal of a Bosch front loader.
This video will show you how to change a door seal on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2011 | Bosch Washing Machines
Key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Jan 06, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Machine won't spin... Machine gets water,
only be one thing, the wig-wags are not shifting transmission into spin if everything else seems ok in operation
Aug 23, 2009 | Washing Machines
Bosch Axxis WFL 2060 washer leaks
Hi. Check the doorseal by lifting the folded lip which faces toward the drum opening. Use a torch and carefully examine the doorseal. It may have a small hole which is hard to see at first.
If door seal is ok remove top of machine and check inlet valve. Turn power off and with your hand examine the inlet water valve. If it feels damp on the solenoid then it leaks from there and finds its way around to the front of the machine though the frame work. This leak happens due to to much water pressure at your laundry taps. If so install a pressure reducing valve before the water inlet hose and replace the water inlet valve in the machine as it is now faulty.
0417362396 Melbourne metro area
Regards Sam
Mar 08, 2009 | Bosch Axxis WFL 2060 Front Load Washer
CL on display panel - washing machine will not respond
CL stands for child lock to take it off press and hold TEMP and TIME DELAY at the same time and this should remove it
Dec 11, 2007 | Washing Machines
Bosch wfmc3200uc/01
would need machine in workshop sorry can t help on that one
Nov 10, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
