Televison & Video Logo
Anonymous Posted on Dec 12, 2014
Is there an electric interface on an old Sanyo TV model no. AVM2555? I took it apart and got it to work but it didn't work after I put the cabinet back together.
The power button was broken so I opened the cabinet and manually turned the unit on by pressing the "On" button. It worked as i suspected it would but when i put it back together it didn't work. Any ideas? (My father used to be a radio and tv repairman. That was back in the '50s...)
Level 3:
Top Expert:
  • Sanyo Master 76,851 Answers
  • Posted on Dec 13, 2014
Sanyo Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986609
Points
237762
Check the connection sockets. If you haven't connected the flat cable, that connect to panel board is not in the proper way, this could happen. As you reported here, when you taken out the panel board out, and switched it ON, it has worked; means, the set have no other fault. Ask your father to check this. He can understand it. Check for any minute breaks in the PCB [ control panel] too.
My tv works at my friend house, but doesn't work in my apartment. However all other electrical devices work at my apartment, model is (SLED5000)
Sounds strange indeed. All other devices; except the TV works fine with all power sockets at your house!! Just replace the power pin, at the end of the TV power cord and check. There is nothing more to check for you. It it too do not help you, contact any service technician. Electro help
3answers
What is sap and how do you turn it off
SAP is an alternate audio program usually seen in markets with different languages. The most common is for a Spanish broadcast of an English program. It is also used to provide audio descriptions of programming for the blind. There should be a menu option under Audio to turn this on and off.
Dan
7helpful
3answers
Wanted: 32" Sanyo LCD replacement screen (compatible)
take apart the lcd and find the lcd panel number then email [email protected] to buy a new panel from a factory in china
then put it all together
1helpful
2answers
Sanyo 32
resolder your tv maybe it has a cold solder
TV surface swival security mounts
Madam, in most cases the swivel mounts are fixed at the base of the TVs with a pair of Bolts / Screws and Nuts.
Please check.
2answers
Sanyo Ht32744 no picture
hi there, there is a horrizontal section problem, a defective electronic part is needed to be replaced. do some testing. ty
1year 3month old $1500 Sanyo HDTV stopped working
this is a common problem help start a class action lawsuit to get your money back!!
WWW.SANYOCLASSACTION.WEBS.COM
2answers
Flyback transformer!
I HAVE SANYO TRANFOMER MODEL NOS TSD-025U CAN I USE IN INDIA . THANKS
1helpful
3answers
Sanyo HT32744 Picture mostly green and blue
On mine I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
