Generac GUARDIAN Standby Generator 10 kW/9 kW, Steel, 200 Amp Logo
kathy Posted on Dec 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 10k Generac standby generator..Bought it at end of 2012 and it started every week doing its weekly excerise...Now it decided to not start so it said to replace plugs, oil, filter...I did that
How would I ajust the valves if i need to
  • 2 more comments
  • Greg Hoffman
    Greg Hoffman Jul 03, 2015
    What is your serial num
  • Greg Hoffman
    Or you can go to their web site and enter it to get a manual
  • Greg Hoffman
    http://www.generac.com/service-support/p...
  • Greg Hoffman
    Remember if this helps mark me helpful thank you
non sequiter
Level 2:
New Friend:
  • Expert 161 Answers
  • Posted on Dec 12, 2014
non sequiter
Expert
Level 2:
New Friend:
Answers
161
Questions
0
Helped
56037
Points
249
Testimonial: "I don't see my model # in the manual??? My model# is 5871"
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
WHAT DOES SENSE LOSS MEAN
RPM Sense loss means that the generator controller hasn't received a valid signal from the ignition coils for 3 seconds of attempting to start. Probably a dead or low battery or bad ignition coil. Replace the battery and try again. Call dealer if problem persist.
3answers
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
3answers
Generac gardian model:005885-0 running rough
Check the spark plugs, ignition coil etc and try to start it manually.
Installed a generac 10k guardian standby generator 2 months ago and all was well,self test each week went fine until this week. Seems to have lost power, screen blank and can't reset? How can I get this...
If you installed this 2 months ago, then you are still under warranty. You need to contact Generac directly before you try to fix yourself and void warranty. Not trying to offend, just being practical.
2answers
My standby generator is just cranking but wont turn all the way
If it was installed only five months ago, it should still be under warranty. Call Home Depot and have them send out a repair person.
1helpful
Unit shuts down from overspeed fault unit has 35 hours total run time never ran more than 2 hours 45 minutes rest is excerise time . is this problem with the 15 kw common ?
The engine throttle control is out of adjustment. It needs to be set based on the generator frequency
(60 Hz).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
