Light keeps flashing and machine does not answer after power outage
Tried unplugging device
    Top Expert:
  • Computers & ... Master
  • 23,154 Answers
And what device is it?
Posted on Dec 12, 2014
Answering machine on light keeps flashing but does not turn on unit
The headset(s) and the base station need to be re-sync.
Check the bottom contacts (base and headset) and let them sync (3+ minutes) OVER-NIGHT if the headset are low on battery.
This will sync the security code.
Jan 16, 2014 | Panasonic KX-TG1031S DECT 6.0 Expandable...
Yesterday we had a power outage. When the power came back on, my TV would not work. The green light on the front just keeps flashing quickly. I tried unplugging it, and I unhooked all devices from it as...
Thats caused by weak capacitors on the DM board. They drain when the power is lost then they cant recharge after power is restired. You can get the dm repair kit for your model at www.tvrepairworld.com it contains the repair instructions and the upgraded caps plus other service info on the cd
Jun 07, 2011 | Mitsubishi Televison & Video
Model 29827A...old phone but the one my mom is used to. The answering machine won't come on and the light is not on. Just changed battery not too long ago.
A power outage may have shut the answering machine off.
On mine there is a program button. I can turn my answering machine on or off, how many rings before it starts. If you do not know how to access the phones programs, try unplugging the little square transformer plugged in the electric wall socket and plug it back in.
The phone may tell you how to reset the functions.
Worth a try.
Apr 09, 2010 | GE 29897GE1 Corded Phone
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Answer light flashes, answering machine doesn't answer. have no manual.
Possible solution.
I have the same problem -- I returned the phone and got a new one. 3 weeks later, the power went out -- same thing. Light flashes but phone won't work.
I called Panasonic and they advised me to remove all the batteries from the handsets, and unplug all the bases for 'a few minutes'. This did nothing...when I plugged everything in, answering machine still would not work.
I spoke to my brother who is an electrician, and he said the base has a 'capacitor' in it, and will not drain down (so phone can be reset) unless it's unplugged for at LEAST a few hours. He suggested I unplug everything and remove the batteries and leave it all overnight. Will attempt this and let you know if this is a resolution.
May 03, 2009 | Panasonic DECT 6.0 Expandable Cordless...
Power out when running. showed code F 71 now not working.
After power outage that will happen do this to fix.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
CL code
My phone was also flashing CL and the 0, after a power outage. After I set the date and time it was fixed. Press the flash button on the handset and use the caller ID buttons to set AM or PM; use the numbers to input the correct time. Then press #. Repeat for setting the day and press # again.
Aug 21, 2008 | GE 29871GE3 Digital Answering Machine
Flashing message light
Insert a new 9 Volt battery (machine will work without a battery if you want to ignore the blinking light)
Apr 27, 2008 | Conair TAD2018CG Digital Answering Machine
Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
Jan 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
ATT 5840 answering machine
you need to reset the cordless phone. This sounds like a lightning strike , if it was the phone is finished. Unplug it , wait 20 seconds and plug it back in again.
Oct 18, 2007 | AT&T 5840 5.8GHz...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
