My dommino A300 industriel printer is showing a fault; it says Fall-back jet modulation in use, and I cannot find the problem and solve; I run of ideas, thank you for your halp
Its an amber alarm
    Habit-Forming:
    New Friend:
  • 73 Answers
Check the scanner assembly if is running during printer initialization. If not open the assembly and check the scanner motor circuit if fault replace.
Posted on Feb 11, 2015
How to fix colors running together
First, make the printer self test. If the problem continues, unfortunately your carriageappears to be damaged and is activating all jets when printing. Try to replace it to solve the problem.
Apr 10, 2012 | HP Deskjet D1455 InkJet Printer
I own officejet 4215v it is stuck in the fax mode and I can't get it to go to print.
Hello and Welcome to FixYa!
Sir this problem is due when by chance the Fax Mode is selected as default. To get to the print mode you need to change the mode to print. Try the following:
Click Start >> Print and Faxes (if you are using Win Xp) or Devices and Printers (if you are using Win 7) >> There will be the list of HP Office jet 4215 Fax and HP Office jet 4215 Printer. >> Right click on HP Office jet 4215 Printer ans Select as "Set as Default"
Now try to print again. If printer is still struck on the Fax Mode then possibility is that your printer is locked, In this case you need to Reset the printer: Follow the given steps to do this:-
  • Unplug the power supply from the rear of the product.
  • Unplug the power cord from the electrical outlet, power strip, or surge protector.
  • If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  • Wait 15 seconds.
  • Reconnect the power cord to the power module.
  • Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
Now turn the printer On and now try to print again. I hope if first solution do not work then this will solve the problem. But if still it struck to Fax Mode then its may be a technical or hardware issue, You need to contact HP Support Center to solve your problem.
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 11, 2011 | HP Officejet 4215v All-in-One Printer
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
I have HP Laser Jet 1020 When I print letters
Most cases on that machine it's the transfer roller that does that at 75mm, but could also be drum cartridge or fuser. Use a flashlight and inspect the fuser, shouldn't be toner or image on fuser rollers, If you unplug the machine when the print is in the middle, you can tell if it's before or after the fuser, and after the drum.
Nov 24, 2009 | HP LaserJet 1020 Printer
SCANNER ERROR 12
in my laser jet M1005 printer showing the scanner error 12. kindly help me how i can solve the problem.
E-mail : jkmeher@yahoo.com
Jul 13, 2009 | HP LaserJet M1005 Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
PHASER 8400
1, The NVRam memory is corrupted.
2, A jet heater is not working
3. the electronics module is bad.
Parts possibly bad are the NVM, the Print Head or the Electronics module.
Hard without a manual to determine, all are expensive.
May 30, 2008 | Xerox Phaser 8400 Laser Printer
Hp colour laser jet 2600n
This printer should still be under warrantee, can you take it back?
Oct 16, 2007 | HP Color LaserJet 2600n Printer
Phillips mf-jet 440
I HAVE PHILIPS PRINTER BUT CAN'T OPERATE WITHOUT PRINTER SOFTWEAR. PRINTER MODUL MF JET 495 , I WANT TO DOWNLORD THIS PRINTER SOFTWEAR SO PLZ.
SUGGESTS ME
Mar 26, 2007 | Philips MF-Jet 495 Multifunctional Machine...
82 people viewed this question
k24674
jasbo
jasbo
