Question about MinkaAire Gyro Traditional in Belcaro Walnut with WC220 3 Speed Wall Control Fan
I have a minka wall control (WCS213) controlling a ceiling fan (F502-BCW) but I cant get the blades on fan to turn on, everything else works perfectly.
I have tried turning power button on and resetting and everything works except for blades.
    Genius:
  • Minka Master
  • 1,617 Answers
Call Minka Aire 1-800-307-3267
Posted on Dec 20, 2014
SOURCE: light dims up and down repeatedly
PROBABLY THE WALL CONTROL SWITCH IS BAD.
ASK YOUR LOCAL DEALER TO BORROW ONE HE HAS IN STOCK. AND OR BUY BOTH THE RECEIVER AND THE SENDER. MY WALL SWITCH MALFUNCTIONED.
Posted on Feb 18, 2009
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
SOURCE: F519-ORB stopped working
the first thing i would check is the wire connections under the cover at celing possible loose connection check wire nuts be carful turn power off befor serviceing ps dumb question is the switch on
Posted on Apr 14, 2010
  • 13 Answers
SOURCE: 2 remotes
Yes, If the receiver is the same model number one remote will work for both... (im assuming when you state remote you are referring to a hand held remote? or are you referring to a wall mount remote? Each ceiling fan comes with it's own electrical unit... I currently have some Minka concept fans if your interested in purchasing at a very good price or if I can help you out in any other way please feel free to contact me at payitforwardx2 @ GMAIL . COM I will be happy to help you in any way I can.
Posted on Apr 23, 2010
  • 13 Answers
SOURCE: Noisey Minka Aire Napoli ceiling fans
Minka fan are life time warrantied, have you tried contacting customer service... Minka fans motors have a very simply design... uninstall the fan... try balancing the fan on a table or some where that allows you to remove the shell that covers the main body of the fan... Carefully (someone that is very familiar with the electrical components.) soft wire the fan allowing you to see the motor as the blades turn... You will then see what is making the scraping noise... I may have some extra fan parts that you can easily replace... If you like to write me at payitforwardx2 @ gmail . com I am willing to try to further assist you...
When the fan rotates it makes a loud noise. Sounds like it needs oil. Where can I put lubricating oil?
Simply disassemble where its possible and find the place of the bearings most its short right behind the propellor where the shafts come out the motor if it is hard to find for an accessible place spraying wd40 with the hose pipe on the canister behind the propellors can may be help do not use sewing machine oil because of the time being it accelerates faster dirt in the sliding bush of the shafts.
Apr 25, 2016 | Minka Lavery Minka-Aire F502-Bcw,...
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
How do you tighten the fan blade to the motor hub. My fan is noisy.
Probably need to take the screen cover off then the bottom of the small motor to see if you can get to the screws. Or call Minka Aire @ 1-800-307-3267
Minka aire wall control not working
It comes with a hand held remote. Unless you have the compatible wall transmitter, you'll only be able to use the hand-held remote. The switch on the wall has to be on for the remote to work.
Dec 14, 2013 | Minka Concept II Ceiling Fan
Dryers Logo
723 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
