Question about Toys
How do I get my train engine to reset/change direction?
Wont respond to direction change after recommended "lock Out" remedy in manual, HELP
Change combination on a Saga safe #1100
If you don't have the combination for the safe, you can try to recover it by observation of the lock itself.
NOTE: I never recommend ANY lock disassembly as a DIY project for the same reason that I never recommend using locksmiths for most safe work. Lack of training, knowledge and tools can result in a very expensive lockout.
My recommendation would be to have a trained safe tech from a local safe company either recover or reset the lock.
Aug 05, 2016 | Home Security
Hi, my 2.8 Diesel GWM display both the amber wrench and the check engine lights, it start normal but drive terrible in fourth gear, it sometimes wont respond or delay to respond to the accelerator pedal,...
The wrench means you need to service the engine ASAP. The check engine light has a lot to do with all the pollution control devices on the vehicle. It could be the fuel filter I always recommend to my customers to change them out on a diesel every 15,000 miles . It will save a lot of headaches.
Nov 24, 2013 | Cars & Trucks
Runs only in reverse i have other pre war 1681e does the same
Have you changed transformers? You can also make a Lionel run in opposite direction by using the throttle control...just go to stop and then to power and then back to no stop and right to power. That often works.
Apr 30, 2010 | Lionel Trains 51009 Prewar No 246e O Gauge...
1998 VW jetta hit some train tracks and it now it
You have somehow shaken the crash detection module and now it needs to be reset. I need time but i can figure out where it is for you. Mike. Rate 100% and respond back please.
Jul 28, 2009 | 1998 Volkswagen Jetta
Philips Flat TV locks up on one channel and won't change
hi i need help cause my philips47pfl7704dif7 when i turn on the tv it just turn blue and wont let me change sources or channels . Help me.
Jul 25, 2009 | Philips Televison & Video
Car engine is locked up
OK, if this engine is locked up, the only option in this case is a rebuild. the rod and crank shaft should be pulled for a look and, the head and valve train as well.
Jun 21, 2009 | 2007 Chevrolet TrailBlazer SS
Parental control is LOCK
mitsubishi 45605 . I bought a universal remote and it wont respond anymore. I tryied reprogram and it wont take the old code or any code. I bought a new remote and it wont respond
Apr 11, 2009 | Mitsubishi VS-45605 50" Rear Projection...
The securilock system is not responding
someone may have tried to steal it and the security system was activated. theres a reset switch under the passengers side dashboard
Dec 28, 2008 | Directed Electronics 1100f Ford Pats...
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Toys Logo
529 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
