Question about Nintendo Wii Ultimate Bundle - With 40 Great Games, Docking Station A
Have a ntendo wii u and I didn't git the code.in a hr.
I don't git it
Nintendo wii console overheats when playing and the fan is not working
Yeah for sure you aren't going to want to use it until the cooling fan is operational, you're lucky that you didn't kill it altogether. Try unplugging the fan wire, cleaning the metal contacts, and plugging it back in. If that doesn't do it, replace it. If you can't buy aftermarket cooling fans, try looking for wii parts on ebay. Aside from that, do all you can to keep it cool..... don't stack it in-between other warm electronic components (tv, dvd player, etc.), don't place it on a carpeted floor (the carpet will insulate the heat and keep it warm), etc.
Oct 10, 2012 | Nintendo Wii Console
1997 honda civic died on the road wont turn over
Start with the battery unless fairly new & have that tested
Next turn key on & listen for fuel pump
It may run but not have pressure or volume
Check fuel pressure at motor with a gauge
Any light on dash & you checked for codes
didn't you? What are they?
Turning over & Starting are two different things,
don't use them together,different systems there
Oct 03, 2012 | Honda Cars & Trucks
Nokia 6600, Imei no. 359365004705343. Two viruses are in my mobile.so i will reset it. but i don't have lock code. Send me the solution.
best result : just download unlockme.sis application & install it on your nokia 6600 and open it after 10 to 15 minute lock code appear on display .
to remove virus you have to formatt your phone , frist switch of your phone & start the device by pressing combination key green key ,' * ' , ' 3 ' , ' power on/off switch ' you will show formatting on display , make sure that procees remove contacts messages etc. so please back up your data before formatting
Jul 19, 2012 | Nokia 6600
My ABS/Brake light in dashboard is on .
I didn't have that issue,but I had a 1992 dakota with
rear abs only & I just unplugged the module under the dash
I'm all for diagnosing everything & having it factory stock & working
But you don't need abs on a 4x4 that old & the rear hydraulic
abs unit ,gets so rusty that it is sad.
If you ever replace rusted brake tubing, remove it
They don't check that in inspection
Jun 06, 2012 | 1999 Dodge Ram
How can I connect my wii to the internet through mifi from at&t?
I had some trouble with this one myself, it was the encryption I added to the wireless. Wii didn't want to see the password as it was spelled, but the hex translation of it. This can be found in your router settings, which can usually be accessed through your browser. But I don't use mifi, so things could be different.
The Nintendo Customer Service has some things to try, this is what I found on google:
Don't know how to find your router's password or key?
Look for a sticker on the bottom of your router. Many routers provided by Internet service providers have their default password located on a sticker on the bottom of the router.
Jan 17, 2012 | Nintendo Wii Console
How to fix error code 51099
This is the error code when the wireless card on your Wii is having trouble connecting to the wireless network. It could be the SSID (wireless network ID) was input incorrectly, or if you have used this before, it might also indicate a problem with the router.
If your other devices are connecting OK, I would reset your wireless connection and create a new one for your Wii.
While you didn't mention any specifics about your router or which wireless adapter you are using for your Wii, but if you continue to have problems you may want to use a different wireless security.
If you want to try this but don't know how, please re-post and make to provide the brand and model # of your router and wireless device.
We used a wired adapter for our Wii and it works perfectly.
Nov 28, 2011 | Nintendo DSi Black Console
I got the internet at home now but when i try to get it on my wii it will not do it....please help me
You didn't mention any particular brand of router that you are using, but you can call you router's tech support line and they will walk you through the setup. Don't worry it's a free service you get for buying/using their product.
Sep 05, 2011 | Nintendo Wii Console
No internet service on our wii.
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
Now, select "Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on the right side of the screen, scroll to page two and select "Internet."
Select "Connection 1: None"
(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
Click on "Wireless Connection" and then "Search for an Access Point."
(Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
Select "OK" and the Wii will display all the wireless networks it finds.
Select the wireless network that is yours.
(If you're not sure which is yours, or you don't see any wireless networks, click here.)
Asked to enter a security key?
If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
Don't know your router's security key?
Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand!
Linksys Netgear DLink
Belkin Apple 2Wire
All other brands
Select "OK," "Save Settings," and then "Yes."
The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored
The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select
"Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
The connection test was not successful - If the test was not successful, you will receive an error code.
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jun 28, 2011 | Nintendo Wii Console
Wii controller broke
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 25, 2007 | Nintendo Wii Console
Nintendo Wii Ultimate Bundle - With 40 Great Games, Docking Station A Logo
589 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
