I have just bought a new washing machine bush ... I had to pause a cycle for 24 hrs as waste pipe leaked as not sealed properly.... Now won't finish cycle... Emptied water that was in machine through filter... Everytime I switch machine back on it just fills with water then the two lights start flashing... And I have to empty it again through filter..... I need to void what ever programme it is on... But how... Please help I'm at my wits end..
4 Suggested Answers
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Posted on Feb 21, 2009
SOURCE: stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Posted on Jul 28, 2009
Washing Machine cycle not completing with washing inside I have a Hisense WFNA9012 washing machine that will only finish a cycle when the drum is empty. Put any washing in it and it seems to get stuck 20...
it seems that the water sensor is not working , look for a small 5mm pipe near the bottom of the drum after removing the back panel, take it off and blow gently into it you should hear a click and one when you release the air if you do then the water sensor is in order then go to the small pipe you took it from and clean the [pipe out with a pipe cleaner or a metal rod as this pipe can get blocked with soap goo, replace the pipe and try the machine again. good luck eric
Jan 01, 2018 | Washing Machines
Hello In Blanco dish washer After cycle finishes, dirty water still in the machine and not draining
clean out the filter before the pump
put a drain cleaning product down the sink( not the washer) to remove organic build up in the waste pipes and allow the washer pump to pump out properly
Dec 17, 2016 | Washing Machines
Managemylife com sears
Sounds like this could be a blocked/air-locked filter.
easy fix if so.
First. switch off the Machine at the socket.
Check your washing machine user manual for the location of the pump filter access screw. (Normally situated behind a front bottom clip out panel) ensure you have a few towels and a couple of pans/dishes at the ready before releasing the access screw, expect 2 or three litres of water to drain... and whatever is blocking the filter. (could just be an air blockage or a small object) replace the filter screw and clip off panel, switch on at mains.
Hope this helps.
Aug 26, 2014 | Kenmore 24 in. Electric Laundry Center...
Keeps saying PAU
The PAU, or pause, error usually means that the washing machine cycle was interrupted and was not restarted properly. If you try to modify the cycle or start a new one before the first cycle is complete, the PAU error will appear on the display. If the washer was stopped midcycle and not restarted, the cycle must be canceled or completed before a new selection can be made. Push "Start/Pause" to allow the current cycle to finish before making a new selection, or push "Cancel" to stop the current cycle
Oct 15, 2012 | Frigidaire Washing Machines
Waste water leaking from underneath my zanussi jetsystem ZWF16381
Could be slight hole in door boot seal / or circon pump suspect door boot seal
Jul 01, 2012 | Washing Machines
Zanussi electrolux zwf14581w won't start, displaying Er40
my father had a zanussi dishwasher that did the same thing, turns out one of the door sensors had gone and would not release the lock. had to get an engineer out, luckily it was under warranty.
Apr 05, 2012 | Washing Machines
My washing machine LG WD1238C keeps showing error message OE hose is not blocked or filter blocked does not finish any cycle or work correctly
This sounds like a blockage in the small hose connected to the waste pump. Take the lid off and find the waste pump down near the bottom of the machine below the drum, then remove any one of the hoses connected to the waste pump and check inside the pump to make sure the fan can spin using your fingures, maybe a small kids sock or similar jammed in there, if nothing in the pump check both pipes on the waste pump
Dec 27, 2010 | LG WM-2277HW Front Load Washer
My front load washer goes into pause two min after machine is started i have to press start for cycle to continue and sometimes it does it a second time press start again it will then finish cycle
you should check button start / pause the washing machine, if it is damaged you must replace it with a new one, the damage caused by the push button which is not connected properly.
Aug 11, 2010 | Frigidaire ATF6000ES Front Load Washer
IWater Leak from LG12225FD Washing machine
may be pump...hose seal... in outer tub...cracked inlet valve cracked hose inlet to tub
Aug 17, 2009 | Washing Machines
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Washing Machines Experts
